587,770 active members*
3,189 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Gantry mill for precise milling of aluminium
Page 1 of 4 123
Results 1 to 20 of 68
    Jun 2014
    30
    I will post some pictures and videos here about my new build. It is a moving gantry mill for milling aluminium. Why do it yourself and not just buy it? Well, there are very few machined with small footprint, large working area, not bulky..
    One machine that comes to my mind is Datron.. But its expensive. Most routers that are on market and advertised as capable of milling aluminium are just not rigid. Some origami style made machines are ok for wood, but not so much for aluminium.
    Some basic data:
    Working area: 1250mm x 620mm x 220mm
    Weight: 850KG
    Structure: Stress releived weldment, T slot table 37mm thick made of steel - 200KG
    Bridge: All aluminium made structure
    Milling head: 1x ER25 3.2KW spindle with max 18K rpm, 1x NT30 German milling head, driven with 2.6KW servo motor - max 5000rpm
    Motion: Ballscews on all axes, 25mm square rails on all axes, Mitsubishi MR J3 400W servo motors with 17bit encoders and brakes on all axes
    I will use 3.2KW spindle for tools up to 12mm, and bigger NT30 for larger tools, like surface mill.
    Currently I have 80% finished bridge, electronic is finished.. But I am still waiting on base and table, which should arrive next week.
    Please check video for current progress:
    I have built few routers before, and decided not to go with side arms like most have, as they tend to oscilate no matter how much you reinforce them. So I went with one piece plate in front, and then with various enforcements in all directions to make bridge
    strong in all directions and also to make it torsionally rigid. This bridge will have less than 0.003mm deviation in any direction with cutting force of 30KG in worst Y and Z position - When Z is lowered and Y in the middle of bridge. Actuall cutting forces will not exceed 10KG in any direction. So it should work ok for milling aluminium.
    If any questions, fell free to ask.
    Aug 2014
    60
    Re: Gantry mill for precise milling of aluminium
    Nice one there
    Jun 2014
    30
    Thank you, lets wait and see how machine will behave. I have some high expectations, but you never know until you put all together and test it.
    Feb 2007
    711
    Beautiful work. I was surprised to see Mach3 running on a linux fan's build (why no linuxcnc?).
    Also, unless you made sure against the specs of those ballnuts, I would say you are running them too fast at rapid speed. Why did you go with what appears rolled 5mm pitch, instead of ground 10 or 20mm pitch, especially since you are using 17 bit encoders?
    Jun 2014
    30
    Quote Originally Posted by alan_3301 View Post
    I was expecting question about why not linuxcnc, as my nickname suggest Im more of a linux user I started using mach for my first build and I found cheap and reliable USB motion control card for it. About ballscrews, you are corrrect. If I had unlimited budget, I would go with 10mm pitch ground ballscrews. I actually already have some rexroth brand new 40mm diameter C3 ground ballscrews with 40mm pitch, but they are for another build, and only ballscrews cost more than this whole machine. But as this motors are "only" 400W" I think 5mm pitch is OK, it is small machine, so I dont need rapids of more than 12M/min, and I also think 17M/min is too fast - 3400rpm. I will run them at max 2400rpm. When you go with Chinese ballscrews, I think it is better to go with 5mm pitch, at least in my case as I dont need very fast rapids, due to force of the ball on screw. 10mm pitch screws will produce twice as much force on the wall of screw, and I wouldnt be surprised to see backlash even faster on 10mm pitch screws.
    May 2011
    790
    Quote Originally Posted by linux_fan View Post
    The nut on a 10mm pitch Chinese ballscrew is much longer than it is on a 5mm. Not sure how this effects the force on the wall of the screw. Regardless, you are using servos that are capable of higher speeds compared to steppers, and whip doesn't seem to be an issue for you, so I have nothing but praise for you and your design decisions on this build. Truly an awesome build sir. I come back every now and then to look at how you've done some things. Certainly one of the best builds as far as quality and performance go.
    I just have one question for you. Where did you buy your ballscrews? I've been reading some horror stories about Chinese ballscrews, but I also know that some of the Chinese stuff is great quality, you just have to pick the right supplier. Looks like the ones you bought are performing well. What are your opinions?
    Jun 2014
    30
    Glad you like it. Since I got it in motion, I made a lot of parts for some other machine, and it works great. I have also bought BT30 ATC spindle for this machine, I will post here when I upgrade it. Yes, you are right, quality of Chinese stuff is very different. I am lucky I have a great forwarder there, so he finds good quality for me. Ive attached some pictures, This is woodworking machine I am making for a friend of mine. All of the milled aluminium parts I made on my smaller machine.
    May 2011
    790
    You're clearly a CNC genius!
    Is that 4 pneumatic cylinders for the counterbalance? Where is your reservoir, are you routing your tube throughout the entire cable chain?
    I'd be very interested in hearing more about how you are accomplishing the work holding. I am aware that some machines like Biesse do this, I haven't seen it on a DIY build until now, I have been thinking of something similar on my machine where I will have a 4th axis under the table, was thinking removable table, but sliding table supports may be better. That's one thing I haven't finalized.
    Jun 2014
    30
    Progres.. Table is finished.. Milled and grinded.
    Jun 2014
    30
    Finally, yesterday bed arrived. I already put table on bed, gantry is also on its position and few other items are already mounted. Screws from table and gantry are not tightened yet, as all needs to be aligned first.
    Attachment 350416
    Attachment 350418
    Attachment 350420
    Attachment 350422
    Attachment 350424
    Attachment 350426
    Attachment 350428
    Attachment 350430
    Attachment 350432
    Attachment 350434
    Apr 2006
    3498
    amazing design and neat job on that machine..difenitly you will precisely machine aluminum as well as steel
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Jun 2014
    30
    Thanks. I am not sure about steel, as steel needs very rigid machine, but aluminium should be no problem.
    Yesterday I made some progress with power cabinet..
    Attachment 350630
    Attachment 350632
    Attachment 350634
    Aug 2004
    782
    Outstanding work.
    Probably the best small one I have ever seen, since 2003.
    Jun 2014
    30
    Thank you
    Apr 2006
    3498
    My Optimus Prime 4G CNC router made of Wood+Aluminum+Steel can cut Carbon-steel quite easily... Your will definitely...
    Nov 2012
    220
    Well done! Great use of the 19 inch rack cabinet. Best gantry mill I have seen on here.
    Jun 2014
    30
    Thank you. Yes, rack cabinet works good, and I also like that it has all four sides removable, so you can easily access items inside of it. Cable carriers are not installed yet, ton of other thing are still missing, but I connected cables from motors, just to make few test cuts. I will post video of it.
    I absolutely love this! I found it on youtube, it made my day and I really cant wait to upgrade my machine now!
    Jun 2014
    30
    First cuts made! Havent made video yet, Ill make it when machine has cable carriers and all other items finished.
    When I compare part with parts of my gantry, which were milled on HAAS, mine actually have better finish. Probably because I used brand new endmill.
    Aug 2008
    1186
    Awesome work and great build!! Keep it up and finish it, often times it's ready to start using the machine and things are left un finished!
    Sent from my QTAIR7 using Tapatalk
Page 1 of 4 123
  1. Aluminium Gantry Router
    By JermNZ in forum DIY CNC Router Table Machines
    Last Post: 03-17-2019, 09:54 PM
  2. Homemade Mini CNC Milling Router Mill DIY X Stage Frame Axis Slide Aluminium
    By doitbymyhand in forum DIY CNC Router Table Machines
    Last Post: 05-29-2016, 01:23 PM
  3. Homemade Mini Milling Router Mill DIY X Stage Frame Axis Slide CNC Aluminium
    Last Post: 05-29-2016, 01:18 PM
  4. Smaller milling machines Bed mill vs plano/fixed gantry mill
    By nilrods in forum Drilling- and Milling Machines
    Last Post: 12-17-2015, 10:34 PM
  5. Precise holes for bearing -> what endmill for aluminium?
    By mitis in forum MetalWork Discussion
    Last Post: 08-20-2014, 06:39 AM
