587,173 active members*
3,529 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 440 not moving correctly after controller swap
Results 1 to 5 of 5
    Oct 2004
    298
    Hey guys! I have one of the early 440s that had a firmware issue with the MX3660 controller. Tormach sent out a new one to swap out and I'm having some issue with the new one. Long story short, I was setup up a new piece to machine and things seemed strange. The G30 went to the wrong place, and everything just kinda seemed a little off. As it turns out, the axes aren't moving the correctly amount. I was zeroing my workpiece and it said the tip was 1" above the workpiece, but it clearly wasn't. So I used a 123 block and confirmed. When the machine says it moved 1", it's actually closer to 1.25". So, all the movements (x, y, and z) are about 25% off. Did anyone else have this issue? The first thing I thought of was microstepping, but that would be a factor of 2 right?
    YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
    Oct 2004
    298
    Re: 440 not moving correctly after controller swap
    Fixed!
    As it turns out, they set all the DIP switches on the controller upside down, so not only was it running at some strange microstepping profile, but it was also about 1/4 the power. good thing I didn't try to cut anything!
    Feb 2006
    7063
    Quote Originally Posted by cowanrg View Post
    As it turns out, they set all the DIP switches on the controller upside down,...
    Musta been setup for a machine in Australia! :-)
    Regards,
    Ray L.
    Feb 2006
    7063
    Those drivers have micro-step settings for 1/8 and 1/10. If yours are set for 1/8, but should be 1/10, your moves will be 25% too long. 1/8 has switches 4/5/6 seet to Off/Off/On, while 1/10 has them set to On/On/Off.
    Regards,
    Ray L.
    Oct 2004
    298
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Yep, that's what it turned out to be. I didn't realize some drivers had 1/8 and 1/10 settings. Glad it's fixed now though.
  1. Swap controller to lathe version
    By Mooser in forum Tormach PathPilot™
    Last Post: 04-24-2016, 12:04 AM
  2. Willing to PAY someone in Tac/Seattle to help swap controller card 6515 to 608
    By kenm010168 in forum Uncategorised CAD Discussion
    Last Post: 02-27-2015, 09:59 PM
  3. Willing to PAY someone in Tac/Seattle to help swap controller card 6515 to 608
    By kenm010168 in forum DIY CNC Router Table Machines
    Last Post: 02-27-2015, 09:05 PM
  4. Machine not moving correctly
    By johntech in forum Machines running Mach Software
    Last Post: 02-10-2012, 03:44 AM
  5. controller for small cnc mill + motor swap (emco f1)
    By slow_rider in forum Benchtop Machines
    Last Post: 02-22-2008, 03:19 AM
