I saw on different website that servo motor are more efficient and the laser engravers I saw seems to be more precise and faster with that kind of motors .
So is it possible to change from step motors to servo motors on our K40 laser engravers ??
If it is using a control such as Mach etc, the controller does not know what motors you are using so if you replace the steppers with servo's, as long as the drives are replaced and tuned to the motors, it should be possible.
Al.
Albert E.
thanks for the information !
thats the thing, its not the motors only that create precision, its the entire motion system, play in belts, play in linear stages, backlashes, etc.
motion system of the small K40 is just incapable to provide for any level of precision, so whats the point sticking precise motors?
Hello, this is Nolan from Thunder Laser, I post a video about the difference between stepper motor and servo motor.
Page not found - Thunderlaser
You mean this video:
https://www.youtube.com/watch?v=ZFym1H5e75w
It's really faster than stepper motor
here too:
https://www.youtube.com/watch?v=jfQN4ip8vLQ
it is why we use servo motor not stepper motor.
Mars (Plus) - Thunderlaser
true, we all have our financial constrains.
but if your goal is to have more precise machine then throwing servos on a K40 will not get you any closer to your goal. and changing the entire motion system does not make any sense financially.
