587,487 active members*
3,301 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Inexpensive source for NEMA 23 270oz steppers?
Results 1 to 17 of 17
    Jul 2003
    92
    I need three NEMA 23 270oz steppers, and I'm wondering if anyone has any knowledge of inexpensive sources for them? I'd like dual shaft, as I'll be needing to use dampers.
    Jul 2009
    85
    Re: Inexpensive source for NEMA 23 270oz steppers?
    Define inexpensive
    Jul 2003
    92
    I know it is a stretch but if I found find three for around $75 I'd be able to swing that.
    Dec 2013
    18
    you can take a look at the Stepper Motor and Controllers from Motion Marketplace...
    -Frank
    Jan 2008
    853
    I bought from Kysan with good results. $25 is a bit of a tough pricepoint though ... And shipping
    Stepper Motors:57 mm NEMA 23
    Paul Rowntree
    Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
    Jul 2003
    92
    Quote Originally Posted by PaulRowntree View Post
    Huh. Not sure which is appropriate. I have a Xylotex controller. I know I need bipolar, but I'm not sure on phase. Google says 270 oz/in is 20.69 k/cm. Any idea which one of those would be a good match?
    May 2014
    182
    Quote Originally Posted by cgallery View Post
    Is it 270oz/in holding torque that you need? Or is this a dynamic torque requirment?
    Jul 2003
    92
    Quote Originally Posted by UA_Iron View Post
    Well to be perfectly honest, maybe neither.
    I had thought I needed to upgrade my motors from the original 116oz motors because of stalling problems. But after doing more research, I came to the conclusion that I may just need dampers. But I have single-shaft motors (and no room to add dampers on the screw side), so thought maybe what I needed was newer bigger motors with dual shafts to which I can add dampers.
    But even more research seems to indicate that swapping out for an Automation Technologies or Gecko controller would be an even better bet.
    So plans are now to save my pennies for an Automation Technologies controller and give that a spin. If I determine after this that I need larger motors, then I'll add those. But at least I'll have a controller that minimizes resonances right out of the gate.
    35538
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2009
    85
    I always buy from automation tech
    Jun 2012
    817
    I know of a place to buy 291 oz in NEMA 23 for ~$25 ea. but not in dual shaft.
    Jul 2003
    92
    Quote Originally Posted by Devastator View Post
    Yeah I really need the dual shaft because I need a way to mount dampers. My machine is tiny so no room to mount them anywhere but the 2nd shaft, I don't think.
    Jun 2012
    817
    Dampers can be added to the end of leadscrews opposite the motors with the same result.
    Jul 2003
    92
    I know, but I don't have room.
    Jan 2005
    1695
    I have these:
    NEMA23 282oz/in 3A Stepper Motor
    They will give you high speed. With weak drivers like the Xylotecs, you will get a slight reduction in static torque, but that almost never matters.
    Jul 2003
    92
    Further update: My problems stemmed from a parallel port misbehaving. I did go with a UC100 motion controller, and it solved all my stalling problems. I can't say enough good about it.
    May 2005
    1397
    There is a list of motors at:
    Good Unipolar Stepper Motors
    Some of which have very low cost sources. E.g. you can get good motors out of old dead copier.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. Source for inexpensive self leveling epoxy for railways
    By thunderdork in forum Epoxy Granite
    Last Post: 08-26-2014, 11:40 PM
  2. Source for inexpensive scales (for DRO use)
    By jderou in forum Want To Buy...Need help!
    Last Post: 02-15-2014, 01:47 AM
  3. Good source for inexpensive solenoid valves?
    By fuper in forum Hobby Discussion
    Last Post: 12-11-2010, 03:52 AM
  4. need inexpensive nema 23 425 oz-in drive board
    By wlsn.chrs in forum Stepper Motors / Drives
    Last Post: 08-18-2009, 03:18 AM
  5. source for inexpensive 3-d probe?
    By cncuser1 in forum Digitizing and Laser Digitizing
    Last Post: 11-16-2006, 10:32 PM
