I bought New Liyang 800W Water Cooling CNC 3040 Z s Milling ENGRAVER 2013 Hot Sell Item | eBay and are having problems running the spindle.
I have run successfully just testing at low RPMS like 5000, but yesterday I tried running at more relevant 18000 RPM's and the following happended:
Everything looked good at first, the spindle was spinning up OK. Then I noticed something smelled "hot" and the spindle stopped.
The VFD showed errorcode E002, which according to the manual means "Power module fault" caused by one of:
- Acc/Dec time is too short.
- Short-circuit on output side of inverter
- Power module damaged
- Exterior disturbances
When I try to run the spindle now, even at lower speeds which worked fine earlier, it starts to spin up but very soon stops with the same errorcode.
I have tried increasing the Acc/Dec time, but no luck.
Of cource what I am most worried about is that the VFD-controller broke, and I have to get a new one.
Any ideas/suggestions to try before I give up and order new controller?
Any help appreciated.
