587,507 active members*
3,099 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Feedrate issue with Madcam
Results 1 to 12 of 12
    Nov 2008
    43
    I am running the latest version of MadCam but have run into a feedrate issue that is causing me problems.
    The feedrates for cutting are not always being set properly after a rapid travel. I am using the default ShopSabre post processor. Below is an example where the feedrate for x and y is NOT being set after rapid travel.
    G80 G90
    M3
    G1 X9.0620 Y6.5940 F2000
    G1Z0.3125 F2000
    G1 Z0.0000 F150
    X9.0536 Y6.5963 Z-0.0015
    X9.0089 Y6.6068 Z-0.0095
    X8.9643 Y6.6127 Z-0.0173
    As you can see above the cutter is put into starting position for x, y, and z at 2000 feed rate. The Z is then plunged at F150 but the X and Y never get changed from 2000 to the proper cutting speed of 150. Of course I have the proper feed rates set for the cutter. What is odd, is that later in the cut after a rapid jog it will sometimes do it properly.
    Here is a snippet of code from later in the same file where everything is set properly. I have highlighted in red where the feedrate is now set properly.
    G0 Z0.5670
    G1 X12.5940 Y14.4807 F2000
    G1Z0.2500 F2000
    G1 Z0.0000 F150
    X12.6250 Y14.4673 Z-0.0058 F150
    X12.6696 Y14.4477 Z-0.0143
    X12.7143 Y14.4278 Z-0.0228
    X12.7589 Y14.4076 Z-0.0312
    Is there something I may not have set up properly?
    Jun 2003
    2103
    jeanyes are you running the new beta of V5 or the latest version of V4?
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Apr 2003
    1357
    Can you attach a copy of the post you are using? I don't have a copy of that post saved on my hard drive. This looks like it can be fixed with a simple edit to the post.
    Dan
    Nov 2008
    43
    @turmite: I am using 4.3 - I did not realize there was a beta available for 5. I will grab that to see if my problem goes away.
    @Dan: Attached!
    Attached Files Attached Files
    Apr 2003
    1357
    Hi Jeanyes,
    Doesn't the G1 and the feedrate from this line: G1 Z0.0000 F150 apply to the following lines as well? The G1 should be implied on the following XY move along with the feed. This is called modal G code. The G1 should be modal (applied to the next lines) until another G code, such as G0 is encountered. When I look at the corrected code at the bottom of your post, your red F150 is being applied to the next set of XY moves, so this tells me that your controller supports modal G code.
    This is how I see the code:
    G80 G90
    M3
    G1 X9.0620 Y6.5940 F2000 <<<positions in X and Y using G1 at F2000
    G1Z0.3125 F2000 <<<neither the G1 or F2000 are necessary as the previous line defined these parameters
    G1 Z0.0000 F150 <<<the feedrate is now changed to F150, but the G1 is still unnecessary here
    X9.0536 Y6.5963 Z-0.0015 <<<this move should continue as a G1 linear move at F150 from the previous line
    X9.0089 Y6.6068 Z-0.0095 <<<this move should continue as a G1 move at F150
    X8.9643 Y6.6127 Z-0.0173 <<<this move should continue as a G1 move at F150
    Continue with XYZ values until a rapid (G0) is required. After that, the rapid (G0) will continue modal until a G1 is encountered.
    Your simplified code would look like this:
    G80 G90
    M3
    Z0.3125
    Z0.0000 F150
    Did you run this code on your machine? If not, maybe give it a try. I can probably tweak your post to add the redundant code, but it shouldn't be necessary.
    Dan
    Apr 2003
    1357
    I noticed in your post that you are not taking advantage of the approach feedrate (Feed Z). I added this and also added a section that will put your feedrate in the first G1 move after the approach. This is now necessary as the approach could be at a different feed (if that's how you defined your tool).
    I have attached my revised post. See how it works for you. If you use coolant, I could show you how to control that in the post too.
    Hope this helps,
    Dan
    Nov 2008
    43
    @Dan: I believe what is happening is that - yes, my machine does support modal g code BUT it is only on a per axis basis. So you must change the feed rate for each axis independently. Setting the Z to F150 does not seem to affect the x and y so they are still locked at 2000.
    Now, there may be a setting in WinCNC that will fix this issue for me so that all three axis are set when one is. I will call the manufacturer on this when I get the time. I'll report back here in a day or two once I get a few rush jobs out.
    On a side note, the way I've been dealing with this is just to set the default rapid speeds to 150... It slows down the overall cut time slightly but I have no risk of breaking more of these tiny 1/8" bits.
    Thanks for the input.
    Jean
  1. Madcam issue (coordinate zero)
    By Woodworker24 in forum MadCAM
    Last Post: 07-25-2011, 01:36 PM
  2. USE MADCAM WITH MY EDM???
    By Steve.B in forum Waterjet General Topics
    Last Post: 01-22-2010, 07:08 PM
  3. How do you use Madcam?
    By turmite in forum MadCAM
    Last Post: 07-28-2007, 07:12 PM
  4. New US rep for Madcam
    By turmite in forum News Announcements
    Last Post: 07-08-2007, 01:14 AM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
