587,515 active members*
3,070 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Servo driven turn-key linear stage? What's available?
Results 1 to 3 of 3
    Mar 2007
    23
    Hi all,
    I'm looking for a turnkey linear stage with the following specs -
    1. driven by a servo with feedback. (could be a stepper, but I need PID)
    2. ~12" of travel (this is negotiable)
    3. potentially has an integrated driver (or will work with a G320)
    4. ballscrews, not leadscrews.
    I've scoured eBay and the classifieds here trying to get a sense of what is available, and there seems to be a weird gap between the DIY stuff and the "made for laboratories" stuff. Much of the "made for laboratories" stuff seems to require proprietary drivers and cost a fortune, and the DIY stuff is, by definition, not exactly turnkey. I'd be happy to assemble from a kit, but don't want to be machining parts myself if I don't have to.
    I'm thinking in the $300-$700 range, am I way off? What am I missing here? Thanks for any insight.
    Mar 2011
    I can provide u but only for pakistan if u interest write me.
    [email protected]
    Sep 2010
    1765
    force (thrust) required?
    speed required?
    explain why you want servo instead of $ 12 dc motor?
    any size restraints?
    Add these tidbits and I can show you what thomson has.
    http://kollmorgen.com/en-us/misc/linear_positioners/
    w/o servo or ballscrew they typically run from $ 300 to $ 5,000.00. w/servo (no drive) and ballscrew typically $ 1500 to 10,000.00............ but give rest of the info above and we will look!
  1. Affordable Linear Stage
    By TahoeTomahawk in forum Linear and Rotary Motion
    Last Post: 07-07-2010, 08:40 PM
  2. Replies: 4
    Last Post: 08-25-2008, 08:30 AM
  3. Power stage of Rutex servo card
    By bunalmis in forum Servo Drives
    Last Post: 11-05-2006, 10:13 AM
  4. Servo driven machine, do I have to put steppers on it?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 12-12-2005, 09:03 PM
  5. servo driven mini mill on ebay
    By qsacracer in forum Benchtop Machines
    Last Post: 06-28-2005, 09:29 AM
