587,626 active members*
3,022 visitors online*
IndustryArena Forum > CAM Software > UG NX > rotary axis help
Results 1 to 6 of 6
    Apr 2010
    16
    rotary axis help
    Please can anyone advise, I am trying to produce a rotary axis milled part by rotating the b axis and spiraling along the part in x. When I verify the path it looks great but when I post it I have x,y,z,b axis moves how can I stop the y axis moving so that the mc only moves in x,z,b axis? Thanks
    Feb 2006
    146
    Make sure the Tool axis is pointed away from the center of rotation and the Projection Vector is Toward the center of rotation. I will often use away from line for the tool axis and define a line thru the center of rotation. What are you using as the Drive geometry?
    You may need to create a cylinder and use that as the drive geometry.
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
    May 2010
    use lock axis... is functional...
    ANDRÉ LUIS DO NASCIMENTO
    SPECIALIST CAM APPLICATIONS MULTI AXIS / IS&V (NX)
    Apr 2010
    16
    Thanks for your suggestions, how do I lock axis?
    Feb 2006
    146
    Lock Axis
    Quote Originally Posted by seven3 View Post
    From the List of User Defiend events select Lock Axis
    Enter the Axis you want to LOCK and the Plane of rotation
    From your description you want to lock the Y axis and the rotation plane sounds like the ZY - this you may need to test
    Post your program and see if this forces rotary motion.
    May 2010
    GO FOR USER DEFINED EVENTS (UDES)
    PUT WORD "L"
    GO FOR TESTING ..
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-12-2013, 09:32 AM
  2. Rotary head development 3 axis -> 5 axis
    By Mr Helmut in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2010, 11:26 PM
  3. Rotary axis
    By WinD84 in forum LinuxCNC (formerly EMC2)
    Last Post: 02-23-2010, 07:54 AM
  4. Dro on a rotary axis.
    By Smackre in forum DIY CNC Router Table Machines
    Last Post: 01-16-2007, 02:45 PM
  5. 4 Axis Rotary
    By Smackre in forum Mastercam
    Last Post: 08-09-2006, 05:28 PM
