587,836 active members*
5,491 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Phoenix Gleason 500HC CNC Hypoid cutting Machine No. 899401 with GE Fanuc Series 150M
Results 1 to 2 of 2
    Dec 2006
    310
    Dear All
    Subject Machine is working fine.
    Please find below details of Hard Disk in the subject machine:
    HDD UNIT A08B-0047-C011 NO. N0398
    MODEL M2611SA
    P/N (Part No.) B03B - 7065 - B111A#LP
    FUJITSU LIMITED MADE IN JAPAN
    SER. NO. 575635 DATE 1994-10
    RATING +12VDC 2.0A , + 5VDC 1.0A
    There is white round sticker, marked at the bottom of it as Label G
    This Hard disk has a 4 pin power connector and 50 pin data cable (25 X 2rows)
    Please let us know on how to take clone (or complete image) of this hard disk
    Best Regards,
    M. Rishikesh
    Aug 2011
    2517
    Its a common Fujitsu M2611SA 45MB SCSI-1 hard drive.
    Cloning it is very simple using any PC with SCSI interface and hdd cloning software. Use any larger size SCSI-1 or SCSI-2 HDD. The cloning software will copy the same data and the remaining unused space will be ignored.
    When chaining multiple SCSI devices in a PC the SCSI ID and SCSI termination must be set correctly.
    You will need a PC with a SCSI card (Adaptec is the most common brand) and cloning software like Norton Ghost, Acronis True Image etc
    Do it immediately the hdd is 17 years old!
  1. Replies: 10
    Last Post: 01-16-2020, 08:45 AM
  2. JD Series Laser Engraving Cutting Machine
    By echojdlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-03-2010, 03:40 PM
  3. Replies: 0
    Last Post: 10-25-2010, 06:39 AM
  4. Replies: 2
    Last Post: 10-16-2009, 01:22 PM
  5. GE FANUC SERIES 150M
    By M.RISHIKESH in forum Fanuc
    Last Post: 10-06-2009, 01:56 PM
