587,905 active members*
3,026 visitors online*
Results 1 to 9 of 9
    Mar 2010
    MACH 3 control
    I am running Mach 3 on a mill. After having had many problems with false limit switch triggering I have now disconnected the limit switches from mach 3 control and have them now operating at 35 volt DC (power supply voltage) a relay which disconnects the DC power to the BOB on the event of E switch or limit switch operation. This system appears to function well but it would be preferable if in the event of a switch tripping it would also stop Mach 3 at the same time.
    Could anyone advise me if this is possible and the way to do it?
    Jan 2006
    2985
    You have noise, it has been discussed here a thousand times.
    Debounce interval in mach3.
    Shielded cable.
    Search
    Matt
    Mar 2010
    I have tried all the usual "cures" but still had problems. Now with no limit switch connection to the BOB they cannot feed back to stop mach 3.
    Jan 2008
    241
    As mentioned before, the debounce feature in Mach3.
    For my toolsetter probe, I had to throw in a small capacitor to stop the false triggers.
    I used a 150pf button cap and that stopped the false alarms for the probe.
    (I didn't need one on the limit switches)
    Try to keep your wires seperated, and use the shielded cables.
    Everything grounded properly?
    Mar 2010
    I have tried the capaitors. In the Mach 3 installation manual it recommends external limit swicthes for larger machines but does not say how to feed back into Mach 3 to switch it off in the event of limit switch actuation
    Dec 2003
    24220
    There are a couple of links here like the one below that address the issue often caused by improper grounding and machine bonding.
    http://www.cnczone.com/forums/phase_...se_issues.html
    Al.
    Albert E.
    Feb 2007
    4553
    Post
    Ploughex,
    As Al_The_Man suggested, use a DPDT relay.
    Since you are switching off the Breakout Board power attach the control wire for the E-Stop input directly to the parallel port (pin 10 is the default in Mach3).
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2010
    Thanks I have adopted the DPDT relay and it appears to be working ok at the moment.
    Dec 2003
    24220
    Quote Originally Posted by ploughex View Post
    What about the Mach E-stop Input?
    Using a contact off the relay.
    Al.
    Albert E.
  1. Servo control with Mach 3
    By papagolf in forum Mach Software (ArtSoft software)
    Last Post: 10-28-2013, 10:19 PM
  2. Mach 3 VFD speed control
    By JpBinc in forum CNC Machine Related Electronics
    Last Post: 06-25-2010, 05:10 AM
  3. Mach 3 No control on Win2000
    By Biff.Hansen in forum Mach Software (ArtSoft software)
    Last Post: 02-08-2010, 08:48 PM
  4. How to control Enable from Mach 3
    By jlobin in forum Machines running Mach Software
    Last Post: 03-19-2009, 06:42 PM
  5. Tangential control with Mach 3
    By krumly in forum Mach Software (ArtSoft software)
    Last Post: 10-24-2006, 01:44 AM
