587,249 active members*
3,562 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > running a 14volt dc motor with 20 volt ?
Results 1 to 10 of 10
    Feb 2006
    1187
    I am doing a powerfeed mod for my milling machine. I am using an old 14 volt Ryobi screwgun motor. I was wondering if I could use a 20 volt 3.5 amp power supply(wall wart) I have to run it?
    I also am using a 12v36v rated speed controller for it.
    Dec 2003
    24223
    As long as you limit the max output voltage, so you do not have a over speed problem, also best if the speed controller has current limit whether the correct voltage or not.
    It is normal for the drive voltage to be rated at least 10% above the motor rated.
    Al.
    Albert E.
    Feb 2009
    6028
    That brushed motor will pull more than 3.5 amps!
    Feb 2006
    1187
    Another guy on another forum, built the same powerfeed mod using the same motor. He said he tested it and barely pulled an amp under load. Plus the clutch will keep it from pulling too many amps, according to him.
    But he used a 12volt pwr supply
    Jan 2005
    1695
    I believe screw guns have electronics built in to control the speed. If you use 20v, you risk exceeding the rating of the transistors and causing them to fail.
    Dec 2003
    24223
    Quote Originally Posted by ZipSnipe View Post
    What is the nature of the speed controller?
    Al.
    Albert E.
    Feb 2006
    1187
    H500 the motor is stripped out of the gun no electronics from the gun are being used other than the motor which has 2 wires coming out of it.
    The nature of the controller? this is what I bought New PWM DC Converter 12V 36V 10A DC Motor Speed Adjuster Controller Driver | eBay
    Please note while the heading says 10 amp what I received was a 5 amp
    Dec 2003
    24223
    I imagine there is not much in the way of current limiting, you may want to fuse it fairly close.
    Al.
    Albert E.
    Feb 2006
    1187
    Thanx Al, I think i will dish out and buy the power supply I need, its only $9 delivered
    Jan 2005
    1695
    Since that controller is rated up to 36v, it should be no problem to use a 20v supply. Speed controller without some sort of feedback don't work very well. The speed varies inversely with the load.
  1. 9 Volt Wal-Wart to 3.3 Volt
    By CURVEDMTL in forum CNC Machine Related Electronics
    Last Post: 12-10-2011, 03:31 PM
  2. Running My 230-volt Induction Motor in Canada
    By jcollier in forum WoodWorking Topics
    Last Post: 12-30-2008, 12:50 AM
  3. Kitamura Mycenter 1 480 volt to 240 volt conversion?
    By mjrockwellus in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2008, 05:14 PM
  4. 220/100 Volt non isolated power suplly for step motor drivers
    By bunalmis in forum CNC Machine Related Electronics
    Last Post: 03-30-2007, 04:36 PM
  5. bridgeport running 220 volt ac motor
    By timmyb199 in forum Bridgeport / Hardinge Mills
    Last Post: 10-10-2006, 05:30 PM
