587,671 active members*
3,386 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 1992 VF2 Alarm 123 spindle Spindle Drive Fault
Results 1 to 16 of 16
    Jan 2007
    122
    So I just experienced this alarm for the first time. It happened at the end of the program shutting down from a 5000 rpm tool path. The alarm popped up and the spindle slowly reduced in speed until it stopped. Anyway I cleared the alarm and started the program again for the new part and after the first tool with it alarmed again but this time give a gear grinding noise like it was changing gears or maybe the spindle lock dog was trying to engage with the spindle still running around 1000 to 1500 rpm.
    Any ideas of what me going on?
    Nov 2009
    27
    Greetings dafowfitdy
    This is just a guess but it is something I need to check on my mach (1994 VF4). I have had experiance on other Haas machines with the spindle encoder belt getting coated with slime by the fan over time and breaking down the rubber and causing the cog belt to start loosing teeth and/or the pulley fills with rubber slime from belt causing the belt to be able to slip and jump time.
    I have also experianced about 1/2 a dozen spindle encoder failures and it causes the spindle load meter to show exsessive load, spindle to act sluggish and causes it to alarm.
    Both are easy to replace. The belt is cheap, the encoder is not. I have been told they are off the shelf encoders that can be purchased outside of Haas, not sure if the time spent finding it is worth it.
    Just my 2 cents
    fastfrank
    Sep 2006
    251
    Quote Originally Posted by dafowfidy View Post
    It sounds to me like your regen unit has gone bad. This is the unit on top of the machine that looks like a stove burner inside a metal cage. It should be on the top left corner (if your facing the back of the machine). Call your HFO and ask how to test this unit to see if it's bad or not. If it's not the regen, then I would next check the Vecter Drive. Good Luck!!
    Just a good ol' boy, never meanin' no harm.
    Joe
    Oct 2009
    192
    Spindle drive fault
    dafowfidy,
    A spindle drive fault can be caused by a few things:
    An overheating vector drive unit - Whilst machine is turned on look at the fans on the top of the vector drive unit and make sure tthey are running, if they are not then the fans are bad and need to be replaced. The Vector drive is located in the electrical cabinet about half way down the right hand side. Take care when going near the vector drive, it still has high voltage even when the machine is turned off and isolated.
    If the fault only happens when the spindle is decelerating then there is a good chance the problem lies with your regen pack, however it could still be a problem with the vector drive unit.
    A 123 spindle drive fault cannot be caused by encoder problems or belt or pulley problems.
    A possible quick fix is a parameter change - however it would effect the performance of your machine slightly. Parameter 186 is the deceleration value of the spindle and is probably set at 500,000. Try altering this to 200,000, Or if it isn't set at 500,000 then just half it. In doing this you are putting less load on the vector drive or regen resistors and could stop your problem for a while.
    Hope this helps
    Jan 2007
    122
    Thanks for the reply everyone. I have had a chance to work on the machine much since my first post. But I have found a couple of other things to note
    (1) The spindle kind of has issues orienting, it may take 4 to 5 rotations before it gets it.
    (2) The spindle will not alarm out as long as the RPM id 400 or lower.
    (3) The the alarm is up I do not notice any LED's lit that are not lit when everything is cleared.
    Haas__man, I will try the 186 parameter but I will still get it fixed properly.
    Thanks again everyone
    Jan 2005
    1880
    I've had this happen on two different machines and both times it was the vector drive unit...after a week of just happening on the Deccel it started doing it on the accel side and that means something in the vector drive is burnt out or getting burnt out.
    but thats just my experience....i don't know at all Hass_man is probably far more knowledgeable.
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Oct 2009
    192
    Sorry dafowfidy,
    I think i have misread your original post. Could you confirm to me that your machine is a 1992 model VF2?
    If it is then you do not have a vector drive. In its place then you probably have a Mitsubishi spindle drive or a yaskawa drive. When the fault happens look at the spindle drive unit, there should be a small lcd display, does it have anything on the display?
    Also when you orientate the spindle does the spindle rotation look smooth? or is it jerky?
    If it is smooth, but too fast for the locking maechanism to lock the spindle, then it is possible to slow this down with parameters. Parameters 72 and 73 are the speed of rotation of the spindle when orientating. One is for high gear. the other for low gear. if you lower the value, then you lower the speed of rotation and give the spindle lock mechanism a chance.
    Hope this helps.
    Jan 2007
    122
    Well on the right middle of the pannel I have a MagneTek GPD 503
    At rest the diplay reads 0.00
    from an rpm of 500 to 7500 it reads from 69.39 to 252
    on error of an rpm of 500 to 2500 the display reads what best discribed as an rr
    on error of an rpm of 5000 + the display reads what looks like an undercase ur
    Oct 2009
    192
    dafowfidy,
    Just had a quick look and found a PDF version of the manual for that spindle drive unit. Normally machines are shipped with the manual, do you have a copy? If you have a look there is a Trouble shooting guide.
    http://www.yaskawa.com/site/dmdrive.nsf/LEG/MNEN-5JLRL4/$File/TM4231.pdf
    Hope this helps.
    Jan 2005
    1880
    the pdf guide link isn't working....just greyed out
    thanks
    Michael T.
    Oct 2009
    192
    link
    Try copying and pasting the link into your browser.
    Jan 2005
    1880
    Cool thanks
    thanks
    Michael T.
    Jan 2007
    122
    Well it appears that I have a "Fuji electric 6mbi50L-060" that is bad. Does anyone have a suggestion for a parts vendor?
    Oct 2009
    192
    Jan 2007
    122
    Smile
    Finnally back to 100%, I replaced that Fuji Module in my original drive and it seemed to orent better but it didnt fix the alarm on spindle decel. So I managed to find a replcement drive for a better price than the rebuild solution and problem fixed. Thanks for all of the help
    May 2012
    I got the same Alarm
    I got the same Spindle alarm currently on our Haas VF4 1994 model. (non vector drive) We have a Magnetek DS309 also controlling this too like the original poster. Our drive was recently rebuilt and still actually under warranty, but I want to know for sure this is the problem.
    Symptoms are I am blowing fuses (top right side of panel 250 vdc 1/2 amp) whenever I try to turn or orient the spindle and it is shutting the machine down.
    The alarm code is 123.
    With me blowing the fuses is it possible that it is still the drive?
    I found the manual for the Magnetek Drive and Checked voltage and b1 and b2 and was reading 190ish. Then there was nothing. Should there always be voltage there or is it only when running? If so I am running into undervoltage issues and that would pinpoint the problem to the drive.
  1. VF3 spindle high gear fault alarm #117 help!
    By JHR1 in forum Haas Mills
    Last Post: 01-01-2010, 05:39 PM
  2. Alarm 235 spindle Z fault, encoder belt?
    By slatern44 in forum Haas Mills
    Last Post: 08-17-2009, 07:54 PM
  3. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 05:48 PM
  4. Alarm 235 Spindle Z Fault
    By Gomes in forum Haas Mills
    Last Post: 04-27-2007, 05:26 PM
  5. Spindle Drive Fault
    By n5jjr in forum DNC Problems and Solutions
    Last Post: 03-31-2005, 03:26 PM
