587,196 active members*
2,906 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Result of step/dir generator 0 in example SimpleStepDirAxis0.mot
Results 1 to 5 of 5
    Question Result of step/dir generator 0 in example SimpleStepDirAxis0.mot
    I loaded example SimpleStepDirAxis0.mot on the Config/Flash Screen, then pushed "Move" on the Step Response Screen.
    Result:
    1. Both IO 8 and IO 9 output same pulse.
    2. IO 8 and IO 9 never stop, they always output pulse.
    I don't know that you have result which is like my result?
    I want to configure step/dir generator 0 like the attached image.
    IO 8 (STEP pin) outputs pulse and IO 9 (DIR pin) doesn't output pulse. IO 9 only is used to determine direction of stepper motor. IO 8 outputs the specified number of pulse. Then, it stops and a task is done. Next, it outputs the specified number of pulse again and it stops again,..v..v...
    Can you help me?
    Thanks,
    TQH
    May 2006
    4047
    Re: Result of step/dir generator 0 in example SimpleStepDirAxis0.mot
    Hi TQH,
    It sounds like you are asking if KFLOP can output CW and CCW pulses instead of Step Pulses and Direction. No KFLOP does not support this. An external circuit can be add to do a conversion. Are you sure your drives can not accept Step and Direction or Quadrature mode signals?
    Regards
    TK
    http://dynomotion.com
    I don't understand why IO8 and IO9 output same pulse. How does KFLOP board control a step motor? I think if KFLOP board wants to control a step motor, it will output step pulse on IO8 and output 0 or 1 on IO9.
    I use a motor driver like attached image. And when I tested example SimpleStepDirAxis0.mot with this motor driver and a step motor, no encoder, the step motor didn't run exactly.
    Thank you,
    TQH
    Jun 2013
    1041
    Take a picture of the motor config screen and the step response screen and post them. Also take a picture of any c programs you may be running.
    Ben
    May 2006
    4047
    Hi TQH,
    Yes KFLOP has Step and Direction outputs that will generate "Step pulses" on the Step Pin (ie IO8) with the Direction Pin (IO9) either Active or not.
    It looks like your driver requires SW9 to be off for Step and Direction Mode.
    SimpleStepDirAxis0.mot configures the outputs as "Open collector" which only sink current to KFLOP GND. You didn't include any specification but most likely you would connect those drives PUL+ and DIR+ to KFLOP +5V and the PUL- to KFLOP IO8 and the DIR- to KFLOP IO9. See:
    Step and Direction Setup
    Regards
    TK
  1. Different result with the same materials
    By Term1nUS in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-10-2011, 01:43 PM
  2. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  3. changing result of alarm
    By spock in forum Sharp CNC
    Last Post: 01-26-2008, 04:35 PM
  4. CamPod a USB to Parallel Port Three Axis Step Generator Available
    By Dennis Bohlke in forum News Announcements
    Last Post: 02-21-2006, 07:49 PM
  5. End result
    By Ken_Shea in forum OneCNC
    Last Post: 05-14-2003, 03:06 AM
