587,900 active members*
2,867 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code
Results 1 to 3 of 3
    Dear All,
    can any one help me to solve that alarm 408 servo alarm "serial not RDY", i think the serial spindle parameters no correct, i need the motor code for the spindle motor model αP18, i'm not sure if it is right.
    regards,
    Sting
    I have the same problem :-(
    did you find any solution?
    would be great to hear from you
    Jul 2018
    2
    really?
    I have the same situation.
    the Operator`s Manual says...
    408 SPINDLE SERIAL LINK START FAULT
    This alarm is generated when the spindle control unit is not ready for starting correctly when the power is turned on in the system whit the serial spindle
    The four reasons can be considered as follows:
    1) An improperly connected optic cable, or the spindle control unit`s power is off.
    2)when the NC power was turned on under alarm conditions other than SU-01 or AL-24 wich aare shown on the LED display of the spindle control unit.
    3)Other reasos (improper combination of hardware) This alarm does not occur after the system including the spindle control unit is activated.
  1. Fanuc O-MC Alarm 405 "Z axis wrong (ZRN)"
    By JSaindon in forum Fanuc
    Last Post: 09-19-2007, 04:22 PM
  2. Replies: 14
    Last Post: 01-08-2007, 06:10 AM
  3. Macro alarm "009 ILLEGAL ADDRESS INPUT"
    By theemudracer in forum Fanuc
    Last Post: 12-26-2006, 04:57 PM
  4. Fanuc 18t Turret alarm "1110"
    By senna95 in forum Fanuc
    Last Post: 10-18-2006, 05:03 PM
  5. ALARM!!! "Commanded X Axis move too far / Positive"
    By aimeahz in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2006, 11:51 PM
