587,228 active members*
6,469 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Emco compact 5 conversion using servos. True closed loop using only the printer port
Results 1 to 13 of 13
    Jul 2003
    1754
    I have been working on this for a while but finally got back to it. Using linuxcnc and PWM out of the printer port to $3 pwm modules. The below block diagram is pretty much how the loop is setup.. Although I am not using amc drives - but some cheap pwm modules from amazon. (not pwm+dir but pwm up and pwm down...)
    Attachment 495516
    Oh - I have done a lot of work on this - I did some non circular boring to get a 1204 ball screw to fit into the x axis..
    Attachment 495518
    Explaining the x axis assembly..
    Jul 2003
    1754
    Re: Emco compact 5 conversion using servos. True closed loop using only the printer
    Here is my latest video - just a quick overview so far..
    Jul 2003
    1754
    Oh - and homing of the X axis...
    Jul 2003
    1754
    This is how I am setting up the pins.. I do have a turret now - so that will be pin 9
    Looking at the parallel port - it looks like I have a pci version that runs what is called x mode. This balances in's and out's better..
    Pin
    1 in Estop
    2 out x pwm
    3 out x dir
    4 out z pwm
    5 out z dir
    6 out spindle pwm
    7 out spindle dir
    8 out drives enable
    9 out
    10 in x encoder a
    11 in x encoder b
    12 in z encoder a
    13 in z encoder b
    14 in spindle encoder a
    15 in spindle encoder z
    16 in x home
    17 in z home
    that bore cycle is super cool . I've seen your previous videos for this type of thing and there is no way I can watch them without at least one immediate replay .
    crazy glue is great for broken or loose nails , or when stitches are required
    be interested how you configure your turret . I got one for mine but been using push button to tool change
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Jul 2003
    1754
    Quote Originally Posted by dertsap View Post
    Thanks!
    If you want a painfully long video - I go through my thoughts on setting up the turret...
    https://youtu.be/CPi-kQ9jjJY
    thanks Sam . I was checking out some of your videos and came across that one just a little while ago . I didn't watch the whole thing yet but it looks very thorough , I saved it to my bookmarks and will follow it when I have a bit of time .
    Jul 2003
    1754
    This is the X axis ball nut assembly fit.
    Jul 2003
    1754
    Also playing with missing tooth index (so you can have in effect a 2 channel (A+Z) using 1 input...)
    Jul 2003
    1754
    +/- 10 volts out of the printer port..
    Found some circuits here.. https://www.eevblog.com/forum/beginn...to-10v-signal/
    The first one from the forum seemed simple enough to try - although it took me a bit to figure out the filter was setup as a high pass - not low pass.. After figuring that out it made sense..
    It should be more than good enough to do closed loop spindle control - and constant surface speed..
    Jul 2003
    1754
    getting closer - using a single tooth index to do some simulated threading.. (and home switches..)
    Jul 2003
    1754
    Side quest... Pressurized oiling...
    Jul 2003
    1754
    Printer port vs external interface hardware (mesa)
  1. Are Chinese servos a gamble? Servos vs Leadshine closed loop
    By j3dprints in forum Servo Motors / Drives
    Last Post: 01-05-2018, 07:09 AM
  2. Compact 5 with closed loop servos and linuxcnc
    By samco in forum EMCO CNC Machines
    Last Post: 01-25-2017, 05:23 PM
  3. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors / Drives
    Last Post: 03-09-2014, 11:27 PM
  4. CNC conversion typically open loop or closed loop?
    By foobar42 in forum Benchtop Machines
    Last Post: 10-30-2009, 01:21 AM
  5. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
