587,722 active members*
3,569 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB6560 and stepper 57BYGH633 (current settings?)
Results 1 to 4 of 4
    Mar 2013
    3
    I have board TB6560 and stepper motors NEMA23 - 57BYGH633, connected and working.
    My question is:
    This motors are 3A and I don't know if I should leave current setting on board (75%) like it have came shipped or I should change it to 100%?
    Motors are tried with 75% and working, but if they are 3A should I change settings to 100% to have more power?
    Thank you.
    Jul 2013
    3
    Re: TB6560 and stepper 57BYGH633 (current settings?)
    I know this isn't an answer to your question but I've been scouring this site and others on how to get my setup running. Your steppers are 6-wire so how do you have them connected. I've looked at the setup sheet for my controller and data on the steppers and I can't get anything to work. Any help you can provide is greatly appreciated.
    Aug 2015
    10
    About the 6-wire,there are 2 ways to connect themne is high torque and the other is high speed.it is according to your requirements on machine.
    For example:
    longs motor 23HS8630 6-WIRES.
    High torque: BLK A+,GRN A-,RED B+,BLU B-,leave others alone.
    High speed: BLK A+,YEL A-,RED B+,WHT B-; YEL A+,GRN A-,WHT B+,BLU B-
    You can try it later.:-)
    Any questions,you can send email to us: [email protected]
    Jan 2005
    1695
    To connect a 6 wire unipolar stepper to a 4 pin controller, use the center lead and one of the outer ones from the same phase. This is known as the "half coil" configuration.
  1. Stepper motor compare 57BYGH633 vs 23HS8610
    By Graphicman in forum Want To Buy...Need help!
    Last Post: 01-23-2016, 08:34 PM
  2. TB6560 working, need settings help...
    By d3ath101 in forum Stepper Motors / Drives
    Last Post: 04-14-2014, 10:17 PM
  3. TB6560 decay and current settings. help
    By crimar in forum CNC Machine Related Electronics
    Last Post: 01-21-2014, 04:45 PM
  4. 3rd generation tb6560 board burned up or incorect current settings???
    By austinblake92 in forum CNC Wood Router Project Log
    Last Post: 09-19-2013, 04:12 AM
  5. Stepper Driver Settings (Microstep and Current)
    By maximusalto in forum Stepper Motors / Drives
    Last Post: 03-09-2013, 04:59 AM
