587,837 active members*
3,413 visitors online*
Results 1 to 4 of 4
    Mar 2013
    1
    AC servo as spidle
    Hello,
    Does anyone know how to wire an ac servo as a spindle? My controller which is Chinese SMC55N, has PWM,+10v and CW/CCW and of course, a bunch of output signals for relays. The servo is a cheap (also) Chinese one, 3kw and require +10V, -10V, analog ground and DIR information for controlling it in Speed Mode.
    May 2017
    8
    Re: AC servo as spidle
    once mine arrives i'll be sure to let you know hahaha
    Quote Originally Posted by Ilerim View Post
    Hello,
    Does the controller come with a User manual?
    Or you can ask the maker to send you a PDF file.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Dec 2003
    24220
    If this is a typical P.M. AC or BLDC servo, you cannot use a common VFD for a controller.
    I have tried it with very poor success.
    Al.
    Albert E.
