587,920 active members*
3,615 visitors online*
Results 1 to 4 of 4
    Sep 2014
    8
    choosing from two kits
    my machine dim. is (2400*1200*250) rack and pinion X Y with gear 2:1 or 3:1 or 5:1 ratio. used for wood, plastic and thin aluminum
    i need to choose from to kits
    1- 4 Nema 23 425oz 3A 6Hm with 2 power supply 60V 6A
    2- 4 Nema 34 651oz 5.6A 3.4Hm with 4 power supply 60V 6A
    i need advice please to obtain good torque and speed. all machin built using steel 100*100*3 box
    Sep 2014
    8
    Re: choosing from two kits
    i need advice with appropriate gear ratio
    thanks
    35538
    I already told you in the other thread. Choose a gear ratio that gives you between 3/4" and 1" of travel per stepper revolution. The gear ratio will depend on the size of the pinion you're using.
    I'd choose the Nema 34 651oz kit, if it were me.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2014
    8
    thanks ger21 for your replay
    the choice of the right gear may also depends on the size of motor (Nema 23 or 34) due to the max speed after reduction obtained.
    i also like you suggest Nema 34 651oz specially for heavy steel gantry but i am confused about gear ratio selection
    Information about gear
    1- 5:1 ratio(90 teeth-18 teeth)
    2- 2:1 ratio (40 teeth-20 teeth)
    3- 3:1 ratio (60 teeth-20 teeth)
    the pinion on the rack is 28 teeth
    60 Teeth pinion
    Teeth : 60 Teeth
    Inner hole : 10 mm
    Outside diam : 103 mm
    Wall Thickness : 35 mm
    Width : 15 mm
    Pitch : 5 M
    40 Teeth pinion
    Teeth : 40 Teeth
    Inner hole : 10 mm
    Outside diam : 70 mm
    Width : 15 mm
    Pitch : 5 M
    may help
    thanks
  1. CNC kits in Aus?
    By wixy in forum Australia, New Zealand Club House
    Last Post: 10-01-2019, 10:41 PM
  2. Replies: 2
    Last Post: 09-15-2009, 05:09 AM
  3. kits?
    By cncCNC in forum DIY CNC Router Table Machines
    Last Post: 12-26-2005, 01:39 AM
  4. Replies: 19
    Last Post: 12-24-2005, 07:12 AM
  5. CNC Kits
    By mjp in forum DIY CNC Router Table Machines
    Last Post: 10-12-2004, 12:54 AM
