587,691 active members*
3,695 visitors online*
Thread: Hurco BMC25
Results 1 to 18 of 18
    Jun 2012
    Hurco BMC25
    Hello,
    I bought a Hurco CNC machining center BMC25, serial number BN9-004-040, manufactured in 1990. Normally include machine and calibrated. Hand controls and run all three axis function. When you start a program and turn on automatic mode until I pull the stem rises to the starting position. Please advise how to remedy the problem.
    Thank you for your help
    Jun 2008
    1104
    What is the fault?
    Sep 2012
    Can you write what is the problem? I mozete da napisete na srpskom, ima nas ovdje.
    Jun 2012
    Posle izvršene kalibracije mašine startujem program. Vreteno se diže u početni položaj, pri tom se trese bez obzira na brzinu podizanja glave u gornji početni položaj. Kako se pri ručnom pokretanju sve tri ose normalno pomeraju, imam utisak da je neka upravljačka kartica oštećena.
    Sep 2012
    Ne mora da bude, moguće je da je samo parametar brzog posmaka ( koristi se kod dizanja z osi ) krivo podešen. Koji je softver instaliran??
    Jun 2012
    Nisam siguran, Ultimax 2,
    sa ekrana sam prepisao MASTER PROGRAM BMC20-50 ENG V8.60 TURBO/EXACTOR
    Sep 2012
    jel možete poslati sliku upravljačke jedinice ( konzole ) te možda sliku početnog ekrana nakon dizanja sistema ( pretpostavljam Ultimaxa ).
    Jun 2008
    1104
    OK. Any chance of some English?
    Sep 2012
    Off course, i am sorry. He told me that everything is ok when he is driving axis except when machine is going with Z axis in tool change height. I ask him for software version and servo pack type. Do you have any ideas? I think only the fast move servo parameter is wrong in software...
    Jun 2008
    1104
    Ask him to reduce the rapid traverse rate in machine parameters and see if it runs ok. He may need to adjust the gain on the servo amp.
    His machine came from England (a company called Impcross engineering).
    Sep 2012
    You have access to a lot of information :-) Yes, i also mean to tell him that but thanks ( in his name ) for advice.
    Jun 2012
    Yes, it's true, the machine arrived from England. I reduced the rapid traverse - General Parameters (1000,5000,6000) machine - shake at raising the spindle to the starting position.
    Jun 2008
    1104
    Broken encoder coupling? (Between the encoder and ballscrew).
    Jun 2012
    Are the encoders on all three axis Hurco bmc25 the same type? Can be confused with each other, in order to test their validity?
    Jun 2008
    1104
    Yes they are.
    Jun 2012
    We replaced the encoders, check the coupling, the error persists.
    Does anyone have a power scheme (wiring diagrams) z / s Smart Axis 415-0176-017 and 415-0177-003 Machine Personality.
    What could be error?
    Jun 2008
    1104
    Can you post a video of the bad movement?
    Jun 2012
    I'm sending you a video clip error Hurco BMC 25.
    What you can not see, I'll try to explain. The machine had an error, could not start.
    Servicer noted contamination boards (they were covered with a layer of oil and metal shavings).
    After cleaning the plate, the machine starts up normally, but part of my programs with which I worked was deleted.
    Programs that want to go, can not be realized due to the mentioned error.
  1. BMC25 - 4th axis
    By gthlm in forum HURCO
    Last Post: 06-08-2016, 12:42 PM
  2. Replies: 2
    Last Post: 12-11-2014, 03:46 PM
  3. Noisy Spindle on Hurco BMC25
    By Geordie Kieth in forum HURCO
    Last Post: 03-07-2010, 08:53 PM
  4. Replies: 2
    Last Post: 01-06-2010, 12:26 AM
  5. Getting a HURCO VMC
    By MBG in forum HURCO
    Last Post: 01-14-2009, 01:50 PM
