587,101 active members*
4,620 visitors online*
Results 1 to 12 of 12
    Oct 2008
    23
    G0704 CNC with servo's
    I am getting together a parts list for my project. I am using NEMA 23 servo's on the XY axis and a Nema 34 on the Z axis. I have been told to use a 1-5 pulley ratio on the X andY I was wonder what one should use on the Z axis?
    As well and recommends on belt and pulley size?
    Mar 2011
    19
    Rather than asking what to use, I think the more important question is; why would I use this, or that specific thing?
    What are your goals for this project?
    Cory
    Oct 2008
    23
    I was just looking for info, on a specific area. Do I have to explain my goals to get info?
    This machine is being built for:
    1 Fun
    2 there is lots of Kit's and doodads already out there and don't have to reinvent the wheel.
    3 I hate steppers
    Apr 2005
    419
    We need to know your servo torque to be able to know the pulley ratio.
    I'd guess 1-10 given that the xy is 1-5 but thats only a guess.
    Feb 2006
    7063
    Quote Originally Posted by accuracymark View Post
    If you want a good result, MEASURE the torque required to move each axis, add in some generous margin (30-50%), then CALCULATE the required reduction to achieve that torque with the motors you intend to use. There's no way anyone else can give you the right numbers, not knowing what motors you're using, what drivers you're using, and what the characteristics of YOUR machine are.
    Regards,
    Ray L.
    Oct 2008
    23
    KL34-170-90 (NEMA 34) Dual Shaft, Front Shaft
    1/2" Rear shaft 1/4" 850 oz-in Peak 90V,
    is the unit for the Z axis
    Still waiting on Gizzly to have the mill in stock. I would be picking it up from there Bellingham store.
    Jun 2005
    53
    I'm guessing you are in BC? I'm in coquitlam with a g0704. I have my ballscrews and 3 axis servo kit ready to go. Using dmm nema 23 ac servos on all axis. My belts and pulleys just shipped yesterday. I am planning to use 2:1 reduction for max 300ipm.
    Oct 2008
    23
    Quote Originally Posted by sdubfid View Post
    Wow fast rapids. I'm good with around 150ipm or so.
    I'm in Langley
    Jun 2005
    53
    If it doesn't work out it will be cheap to change the pulleys. The charts for my motors have flat line torque across the rpm range so I'm hoping it will work well. You are free to come check it out when it's running, most likely in nov sometime. Learn from my mistakes haha.
    Nov 2009
    724
    Wow, I am just over the border from you guys.
    I have spent a bit of time up in POCO doing a little RC racing
    My wife is Canadian, and my in laws are up in Sidney, so I spend a fair bit of time up in the Vic area.
    I have met a few really nice guys up there from here on the Zone.
    Maybe we can all hook up sometime and have a BBQ or something.(summer)
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
    Oct 2008
    1638
    I run those servos with 3:1 pulley ratios (15/45) on all three axis of my RF45 which is a little larger than a 704. At 72 volts your top speed will be around 195 ipm and loads of power, enough to bow a 1/2" roughing end mill like a bannna.
    Richard
  1. What Voltage are my Servo's?
    By austin.mn in forum Rutex Products
    Last Post: 09-19-2009, 11:21 PM
  2. rpm of stepper vs servo's
    By Ed Williams in forum Servo Motors / Drives
    Last Post: 05-15-2006, 01:42 AM
  3. Help, servo's won't move
    By lilricky2 in forum Mach Mill
    Last Post: 03-14-2006, 05:01 AM
  4. What size servo's?
    By PeteZ28 in forum Benchtop Machines
    Last Post: 02-21-2006, 02:46 AM
  5. AC Servo's
    By ty1295 in forum CNC Machine Related Electronics
    Last Post: 04-26-2004, 02:57 PM
