587,879 active members*
4,003 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB 15 II - problem with parameters
Results 1 to 5 of 5
    Jan 2017
    6
    Hello.
    I've got a problem with changing one of optional parameter in Okuma LB 15 II. The problem is that I would like to change a lubrication frequency. Standard setting is 5 minutes. My aim is to excend this time to 10 minutes. Unfortunately I don't have any documentation to this machine. I've found only documentation to older version where we can switch parameter #16 - the operation interval of the way lubrication pump motor for the LB series lathes is set. I thought its gonna be resolution to my problem but with using this parameter i can switch max to 6 min - 5256 Input data overflow ERROR 6. Does anyone have an idea how to excend this time to 10 minutes ? Photos attached. Thank you for your help in this matter.
    Jan 2017
    6
    Re: Okuma LB 15 II - problem with parameters
    #2
    Jan 2017
    6
    #3
    Jun 2015
    4160
    hy i don't know parameters for your cnc, but be carefull with this timers
    common behaviours :
    ... 1) increase off timer = decrease frequency
    ... 2) timer off when axis don't move
    ... 3) change "on timer", thus lube duration
    main factor when changing lube timers is how the machine works, because if the cnc is cutting, than "2) timer off" almost does not occure, and this avoids preesure drop among the lube pipes; as a result, when the pump pumps, at the end will lube
    if cnc is not cutting often, thus there are time breaks, than pump must pump a little more so to build pressure among the pipes, and to lube at the end
    so is important that lube will reach end points, and this is relative to machine usage
    cutting a lot :
    ... off timer does not occure
    ... you may reduce frequency
    cutting less :
    ... longer lube duration
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Apr 2009
    1262
    You typically should not increase the timer duration to that level on a box way machine. You would run the risk of way damage by running them dry. That is why the timer will not let you set it that high.
    That being said, kitty is right that there are other parameters on the newer controls that will allow the machine to "not count" when the axis is not moving. This can save a considerable amount of lube if your machine is idle.
    It is on the same page with your lube parameters. Unfortunately I think it was not yet on the 7000 series if I remember correctly.
    If it is not there, use the e-stop button when idle to save lube.
    Best regards,
    Experience is what you get just after you needed it.
  1. Okuma 43v Diagnostic Parameters
    By ZiItGuy in forum Okuma
    Last Post: 12-09-2013, 07:19 PM
  2. Need Fanuc 18T, OKUMA ACT-15 PMC parameters
    By TedC in forum Community Club House
    Last Post: 06-26-2013, 07:56 PM
  3. Okuma parameters manual
    By cimber in forum Machinery Manuals / Brochures
    Last Post: 01-13-2013, 04:22 PM
  4. okuma parameters
    By ddareddevil in forum Okuma
    Last Post: 12-09-2009, 08:22 PM
  5. Okuma Osp-700m Dnc Parameters !!!
    By miguisu in forum DNC Problems and Solutions
    Last Post: 05-16-2007, 04:13 PM
