587,262 active members*
3,381 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Bought a brushless servo motor, now what?
Results 1 to 6 of 6
    Feb 2007
    11
    I guess I have done a stupid thing, but I hope someone can help me out.
    I wanted to put a brushless motor on my home built mill and found this great deal on this motor on ebay.... Seemed like a good idea at the time.
    It was advertised as an brushless DC servo motor. It has a specifications plate (picture attached)
    What literature I can find from Kobold in germany, it is a three phase synchronous servo motor. Its a Kobold KSY 464.80 servo motor. Not the current model "D" KSY, but the older one.
    Seems like a strong motor, 8000 rpm, 210 volts, 13 amps. So now, I am looking for a servo motor driver to get to power it. And I am lost. I don't know what to get to power it, and I don't want to overspend.
    I really don't need all that power, so if I want to run it at 1/2 to 3/4 hp, and buy a lower voltage/amperage driver, can I? I know it will limit RPM, but I can deal with that with pulley size setup. I'm doing light duty small diameter mills anyway.
    Ideally, I would like to get a 115 ac line powered all-in-one driver that would allow analog speed control as well as future position/step/direction control.
    Perhaps a Axiom DV10 (If I could get one cheap) or one of the A-M-C BE25A20AC devices. Would either of these do what I want?
    Thanks in advance for any thing you can share.
    I'm thinking I got in over my head. Maybe someone here can help me out?
    Michael
    Dec 2003
    24223
    The first thing to establish is what kind of commutation does it have, and if it includes an encoder
    I believe the lower torque values are the operating values, the higher ones are the max before demagnetization.
    Is it a BLDC or a AC sinusoidal with maybe resolver feedback?
    Al.
    Albert E.
    Feb 2007
    11
    The Kobold data sheet I have says these are "three phase synchronous". The usual configuration says resolver, but this motor seems to have a different suffix, IE, the "R6", than the usual R4 suffix. From what I can glean, this seems to be an encoder option. I hope. I won't know for sure until I get it later in the week.
    Anyway, if it's a resolver, I guess I'm SOL. I was hoping to use it to drive a spindle with speed control.
    Dec 2003
    24223
    If you can establish the pole count, you may be able to fit one of the encoders that Renco are dumping on Ebay right now for $20.00, and make it a BLDC.
    Then you could use a AMC drive.
    Al.
    Albert E.
    Feb 2007
    11
    The manual says this is a 6 pole motor. The "464" means size 4, 6 pole.
    Dec 2003
    24223
    So the Renco encoder or who's-ever if you should fit one, should be a /3 for 3 pole pair.
    Al.
    Albert E.
  1. help dc brushless servo
    By zet-jaro in forum Servo Drives
    Last Post: 02-23-2010, 11:44 PM
  2. Make a Driver For Servo Brushless Motor Up to 1.5Kw
    By Chivo in forum Servo Motors / Drives
    Last Post: 09-13-2009, 10:47 AM
  3. DIY Brushless Servo Motor ?
    By epineh in forum Open Source CNC Machine Designs
    Last Post: 06-14-2009, 04:29 PM
  4. Affordable DC Brushless Servo Motor
    By Lemo in forum Servo Motors / Drives
    Last Post: 08-21-2007, 01:10 PM
  5. Compumotor B23 Brushless Servo???
    By CRFultz in forum CNC Machine Related Electronics
    Last Post: 04-15-2004, 03:42 PM
