587,450 active members*
3,076 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > USB Wireless Connection for Tormach Machine Controller
Results 1 to 17 of 17
    Dec 2004
    57
    All,
    I have the Tormach performance machine controller, PN 31520, running the OEM operating system software. I'm interested in attaching it to the home network so I can eliminate the need to access the USB port to transfer .NC files to the machine controller. I'd rather not wire a network cable to the router because of the distance it has to cover, so I'm looking at wireless adapters. The USB adapters are particularly interesting because I can install it without opening the case.
    Has anyone used a wireless USB adapter, similar to these?
    Newegg.com - Rosewill RNX-MiniN1 (RWLD-110001) Wireless-N 2.0 Dongle
    Newegg.com - Rosewill RNX-N180UBE Wireless Adapter IEEE 802.11b/g/n USB 2.0 1T2R / 5 dBi External Antenna
    Thanks.
    Jul 2004
    595
    One thing to consider is that if you connect your controller to your network(if connected to the internet) you will need to be concerned about viruses etc making there way to the controller. You probably shouldnt run virus scan software as it is fairly processor intensive and may interupt the machining process. You would need to experiment I guess.
    The risk may be lower if you do not use any internet or email apps on the controller.
    Re the units you linked... Depending on where your controller is located in relation to your wireless router etc, you may have more of a challenge with getting a good signal with the little tiny one. The unit with the antenna (given it works fairly well) may be better, but its hard to say.
    Remarkable they can make a wireless unit that freaking tiny... Im in the industry and Im still amazed.
    David
    Dec 2004
    57
    Thanks for the input.
    I don't plan on accessing the internet with it or running any sort of email application. No reason to risk the controller. I'm just looking for a handy way to move files. I'll probably add a shared folder to my main PC and access the documents that way so there's no write access to the machine controller from the outside.
    My biggest worry is the installation of the network device on the machine controller. I'm comfortable with Windows software, but didn't know how Windows CE would react to my attempts.
    Quote Originally Posted by David Bord View Post
    Indeed. I'm impressed by this as well.
    I'm definitely leaning toward the unit with the antenna because I suspect the range would be better than with the tiny one. I've got to get the signal through two walls and about 40 feet across a three bay garage to the machine controller. I've got a wireless signal strength measuring app on my phone, so I'll adjust antennas as necessary with that.
    I appreciate the data point, Mark. I'm much more confident in making this move now. Thanks again!
    Feb 2011
    36
    USB versus ethernet?
    Any thoughts on USB interrupts versus ethernet? I read somewhere that ethernet, with a configured, set speed might be more stable from the controller/interrupt standpoint.
    So, to get wireless, maybe use some router/range extender like the Apple AirPort Express? It itself is wireless, but the connection to the controller is plain old wired ethernet. I have a few of these in my house to extend the range of my wifi and to also attach wire-only devices to my network.
    Thoughts? I plan on trying this soon.
    BTW, a simple firewall is also a good idea.
    Dave
    Dec 2004
    57
    Quote Originally Posted by gsnorcal View Post
    Indeed. I'm relying on my router to perform that function, though. I don't do anything that invites bad stuff in, so I should be in good shape.
    Jun 2006
    340
    Re: USB Wireless Connection for Tormach Machine Controller
    Quote Originally Posted by anglin View Post
    What is the app and what model is your phone?
    Thanks,
    Bevin
    Oct 2011
    34
    I've been using a Medialink Wireless N USB Adapter for over a year with no problems. My desk and design computer (and wireless router) are on the main floor and my shop and mill are one floor down. I forget what I paid for it but Amazon has it for $19 now. I did get a long usb extension cable and have the Medialink suspended about a foot below the ceiling. Not sure if I needed to but I've never had any connection issues.
    Mark..
    Oct 2009
    27
    Rather than deal with wireless why not just use ethernet over power adapters like the ones from Netgear:
    Network Powerline Products from NETGEAR®
    No changes to the machine controller necessary as I believe it has an ethernet port and no drivers to install and dork with. I use these in my shop and they have proven to be fast and reliable. They took me about 10 minutes to install and that was because of the dang plastic bubble packaging. I just plugged them into the power outlets and connected the ethernet adapter from the machine controller to one of the adapters and a wired port off of my router and voila. Networked machine controller.
    Mark
    Jul 2007
    1602
    I have a DLink USB wireless dongle on one of my PCs and it works fine. If you put it on the machine controller, remember to disable it whenever you start to machine.
    bob
    Dec 2010
    25
    I'll 2nd the warning about remembering to disable before running the machine. When you send anything over Ethernet, it goes everywhere on your subnet (which for most shops means everywhere). Each machine must look at every packet and determine if it is for them. Most Ethernet cards will do this internally without the PC involved but I'm not sure the little USB will. The result though is that you don't want your controller being interrupted while it's running by someone else transmitting to another machine... Or yours by mistake, disable the port. And for us Homey's, no since in juniors playing Grand Theft Auto or downloading that movie we wouldn't let him go see, messing up our projects.
    Jun 2005
    656
    Alas, the powerline network things won't quite get to my garage for some reason but if they work, they're a good option.
    May 2011
    180
    I have used the ethernet quite a few times on my Tormach controller. Doesn't seem to interfere at all. I am using a wired connection, and my house is pretty busy on the network (about 35 devices on my internal internet).
    Feb 2015
    57
    Check out the Edimax EW-7811UnR2 and/or EW-7811Un I'm going to be trying both of them.
    Jul 2004
    1424
    Holy ancient thread restoration, batman!
    Tormach sells an 802.11n usb wireless adaptor for $15.50:
    34705 - Wireless Network Adapter for PathPilot
    Note this is for use with Path Pilot, as Tormach strongly recommends not using a USB wifi adaptor with mach3.
    Tim
    Jun 2006
    3063
    Netgear has one on Android (WiFi Analytics) and I suppose that most of the major players have apps. A search on Play Store or ITunes ought to turn them up.
    Mike
    Jun 2006
    340
    Quote Originally Posted by MichaelHenry View Post
    Mike
    Thanks Mike.
    Bevin
    Jul 2005
    194
    I use a Netgear WN2000RPT Universal WiFi Range Extender Extender that I got off ebay for $25 and then go wired into the PC. Lets me put the antenna anywhere even up high as the shop is a ways from the house.
    Plus, since it's ethernet, there is less overhead than USB, it will work with any computer and no special drivers loaded. All computers (even PathPilot) talk ethernet. This one even has four eithernet ports so I can plug in a laptop and printer out there as well.
  1. Looking for wireless transfer of nc files to tormach
    By rockclmbr in forum Tormach Personal CNC Mill
    Last Post: 08-15-2013, 12:08 AM
  2. Tormach machine controller
    By jk677 in forum Tormach Personal CNC Mill
    Last Post: 07-18-2013, 09:40 PM
  3. Help with Tormach Electrical Connection
    By kfwittekiend in forum Tormach Personal CNC Mill
    Last Post: 03-13-2012, 05:12 AM
  4. Has anyone used their own pc instead of the Tormach Machine Controller?
    By Smokey911 in forum Tormach Personal CNC Mill
    Last Post: 09-22-2011, 08:25 AM
  5. Parallel Port machine controller to computer connection HELP PLEASE!
    By whipsnade in forum DNC Problems and Solutions
    Last Post: 08-01-2006, 10:45 PM
