587,743 active members*
3,211 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 2600 w/31i control and LNS Sprint 565
Results 1 to 6 of 6
    Jun 2003
    11
    Would anyone have any macro's, and sample program to test this combo out?
    Thanks,
    Gregg
    Jul 2005
    380
    What specifically are you looking to test?
    Jun 2003
    11
    This was a used lathe with out a barfeed but did have the interface, therefore there were no macros for a barfeed. The barfeed came with little documentation, but I was able to get manual and interface schematic from LNS. It's all wired in and seems to function in manual mode. All my current barfeeds are simple push to a stop till bar runs out, no loading or top-cut no real interaction other than end of bar. I've called our local Doosan dealer and he went on about every machine is different and what not. LNS wasn't much help either, but somehow I'm guessing if it was a new machine ordered with barfeed there would be sample program and macro's. I've set the jumper for the barfeed on the machine and set the keep relays for it also. So at this point I only know that m50/m51(can't remember which) calls the barfeed but no documentation on how to use it.
    2932
    Here's a sample from a P240 with a bar feed (don't remember which one).
    O0001(MAIN PROGRAM)
    M98 P8000 (CALL BAR FEED SUB)
    M55 (AUTO RESTART AT M30)
    M30
    O8000 (BAR FEED SUB)
    G00G40G97G99 (SAFETY)
    G28U0W0M09 (REF. RETURN)
    M05P11 (STOP SPINDLE)
    T0909 (INDEX TO STOCK STOP)
    /2M98P8001 (CALL END OF BAR SUB)
    G00 X0 Z0.015 (POSITION STOP)
    M31 (INTERLOCK RELEASE)
    M69 (OPEN CHUCK)
    M51 (FEED BAR)
    M68 (CLOSE CHUCK)
    M99 (RETURN TO MAIN)
    In your situation, you're not going to automatically load a new bar, but I would think you could use the following:
    O8001 (END OF BAR SUB)
    #3000=1 (END OF BAR)
    M30
    This would issue an alarm when the EOB signal was active. I think hitting RESET to clear the alarm would return you to the main program, but I've never tried it, so don't quote me.
    Jun 2003
    11
    Thanks dcoupar, I'll see if it gets me going Mon. a.m. but why wouldn't I be able to load a bar automatically
    since the Sprint 565 is supposed to do just that?
    2932
    Quote Originally Posted by GreggC View Post
    Oops. Sorry, I misread your earlier post and thought you didn't want to auto load bars. Here's both the feed bar and load bar macros.
    O8000(FEED BAR)
    G00G40G97G99
    G30U0W0M09
    M05P11
    T0909
    /2M98P8001
    M31
    M69
    M51
    M68
    M99
    O8001(LOAD BAR)
    (#501 = STOCK DIA)
    (#502 = PART LENGTH)
    (#503 = CUTOFF TOOL WIDTH)
    M10
    M19
    M31
    M69
    M51
    M68
    M11
    (TOP CUT)
    G00G40G96G99
    G30U0W0
    T0909
    G50S1500
    G54X[#501+0.1]Z-#502S650M03P11
    M08
    G94X-0.062Z-[#502+#503/2]F0.012
    Z-[#502+#503]
    G00M09
    M05P11
    G00G30U0W0
    M99
  1. puma 2100sy to lns sprint 565
    By GreggC in forum Daewoo/Doosan
    Last Post: 12-27-2013, 03:00 PM
  2. Paramter on Cent 4 for 200 ipm? 2600 isnt working
    By Brian FRF in forum Milltronics
    Last Post: 06-26-2012, 04:16 AM
  3. Puma 10S - Fanuc OT control
    By jaginst in forum FeatureCAM CAD/CAM
    Last Post: 04-16-2011, 06:12 PM
  4. Puma 200 Gantry Control
    By drummerboy82 in forum Daewoo/Doosan
    Last Post: 12-14-2010, 01:51 AM
  5. Puma 400 with 21iTB control
    By bala955 in forum Daewoo/Doosan
    Last Post: 06-12-2010, 04:57 PM
