587,218 active members*
2,673 visitors online*
Results 1 to 8 of 8
    Oct 2012
    stepper interfacing
    I'm trying to build a simple little desktop 3D printer, I've seen tons of videos of people using CD drives. My question is first of all, how does the computer control CD drives in the fist place, via what code? Second don't CD drives have a built in controller board? Third, couldn't I control a CD drive, motor just from my computer, and not need any other driver boards etc.?
    Right now I have one CD drive i'm testing with, I have it plugged into a external hard drive case, via IDE cable, witch then connects to the pc with USB.
    anyways, is there away that I could control the CD drive, this way? Considering windows does it already when you eject the tray etc.
    anyways I hope somebody can help me with this
    thanks.
    Mar 2009
    533
    From what I know is that the CDROM is similar to a hard drive when connected via an IDE cable. The CDROM drive will understand certain commands that the manufacture created and embeded into the CDROM hardware. These commands are issued to the CDROM via a CDROM driver (software). Your program will then communicate commands via this driver.
    The CDROM will have an address and a data port plus some handshaking signals. The driver will know this too.
    I don't know the actuall commands used for the CDROM so I can't help you in that area.
    Oct 2012
    Is there some sort of software that I can use that will communicate with the CDROM?
    I tried some cnc software but it does not effect the CDROM at all.
    Mar 2009
    533
    Not off hand. The software will most likely be C/C++ and you have to write the program yourself.
    You could check into open source software like Linux and see if you can find a CD-Rom driver that you read the source file and obtain commands from.
    I'm not clear as to exactly what you want to control. Most hints I have seen are only to open the tray, eject a CD and close the tray.
    Reading a specific file would require other commands like those used for the hard drive, but I haven't gotten into such details.
    Oct 2012
    Basically I'm just using the CD drives because they have a nice tray attached and a nice sliding action, also they come with a controller board, eliminating the use for a arduino etc.
    But I don't want to simply just open and close the tray, I need it to move different excrements as you would need for a cnc machine or 3D printer.
    Mar 2009
    533
    It is a novel idea. Unfortunately I don't know enough either to guide you further.
    The tray movement, is that proportional control? I thought that it fully moves open or closed but not proportional (incremental) so that you can't just move it "x" millimeters in or out.
    Do you also use the spin of the platter for some function? If so you also need accurate angular control. Again, I don't know if that is feasable.
    You will need the command set for the controller to go further. If that is proprietary then you will get stuck with the project. You may need to look for an open source controller to get a deeper understanding of the possible controls for the CD-ROM, which I don't have.
  1. Interfacing Stepper Motor
    By circuitx in forum Stepper Motors / Drives
    Last Post: 04-01-2011, 11:39 PM
  2. PMX1250 cnc interfacing
    By steve_p in forum Hypertherm Plasma
    Last Post: 09-24-2010, 10:22 PM
  3. Interfacing stepper motors with computer
    By John DiBernardo in forum CNC Machine Related Electronics
    Last Post: 06-01-2010, 03:19 PM
  4. Interfacing Mach3 to Bandit Control Stepper Driver
    By Astroboy in forum Mach Software (ArtSoft software)
    Last Post: 09-01-2008, 02:41 PM
  5. Makino Interfacing
    By Professorwiz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-22-2005, 04:54 PM
