587,837 active members*
3,526 visitors online*
Results 1 to 3 of 3
    Feb 2008
    4
    signal generator problem? TM2
    i think i have a problem on the 8x4 torchmate 2 system we have. trying to cut 9 squares nested along the y axis. the machine has cut this program before fine.
    yesterday the machine cut the squares in a "staggered" pattern. the machine is shifting on the x-axis between cuts. the program has all the squares lined up flush to the x-axis. the cuts themselves are fine, the cut templates are being cut with the sides parallel with the axis'.
    when the program was stopped the during the run, the program zero was shifted in the x-direction.
    i have doubled checked the programing and it is fine. the problem seems to be further down the line. i was thinking the signal generator.
    help please!
    cheers
    sean
    Mar 2008
    33
    Hi
    Please say clearly again about your problem.I think it's your gear rate lead to this result.
    tony
    Mar 2015
    3
    Re: signal generator problem? TM2
    Posted in wrong thread. Sorry!
  1. TM1 Signal Generator Alternatives
    By runlevel6 in forum Torchmate
    Last Post: 05-14-2021, 04:52 AM
  2. Does the Tormach use a signal generator?
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 07-22-2013, 07:53 AM
  3. Problems with Signal Generator A501
    By PAPAS in forum Torchmate
    Last Post: 10-26-2009, 05:30 PM
  4. Signal generator need help
    By kirkln in forum Torchmate
    Last Post: 12-10-2008, 02:30 PM
  5. SIGNAL GENERATOR 501A
    By ecamacho in forum Torchmate
    Last Post: 01-18-2008, 10:57 PM
