587,255 active members*
3,163 visitors online*
Results 1 to 2 of 2
    Apr 2006
    266
    Estop and limits
    Is it advisable to run the e-stop in series with the limit switches? My e-stop has 2 sets of NC 240v/10A contacts. Is this an acceptable e-stop for a
    110V setup? My on/off switch is also a 240V switch. Is that acceptable for an on/off switch for 110V? Also I have a 125V/15A circuit breaker. Is that acceptable for replacing the fastblow fuse for the main power protection?
    Jan 2008
    136
    yes you can do all you have stated, but only wire up the e-stops to the end limits if they are the emergency end limits, the e-stop circuit is normally a daisy chain of all e-stops. Fast blow fuses are only necessary on spindle and axis drive supply phases, so you should be ok to replace with a correctly rated overload.
  1. EMC - Estop & Active high and low
    By ADucci in forum LinuxCNC (formerly EMC2)
    Last Post: 10-03-2007, 08:06 PM
  2. random estop
    By erase42 in forum DeskCNC Controller Board
    Last Post: 02-03-2007, 12:28 AM
  3. ESTOP keeps happening
    By klick0 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-17-2005, 06:06 PM
  4. Mach 2 Estop problem
    By dentman in forum Mach Software (ArtSoft software)
    Last Post: 06-08-2005, 01:32 AM
  5. Estop
    By HuFlungDung in forum CamSoft Products
    Last Post: 03-06-2004, 08:24 PM
