587,396 active members*
3,623 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Do you think this will be cool enough?
Results 1 to 16 of 16
    May 2014
    19
    Do you think this will be cool enough? I am a bit limited on space and don't know how much heat to expect.
    Attachment 239942
    2x 36 Volts 16 Ampere Power Supplies (the top one gets a hole for its fan)
    4x Stepper Drivers for Nema 23 Motors (3-4A each)
    3x 12cm fans. 2 blowing in, 1 blowing out. Wrong way on the picture :/ (74 CFM / 125,7 m³/h )
    Feb 2007
    4553
    Post Re: Do you think this will be cool enough?
    Quote Originally Posted by spooner777 View Post
    Attachment 239942
    Spooner777,
    If in fact the power supplies are 36 volts 16 amps, the four drives only require one power supply.
    That in itself would reduce heat immensely and save energy too.
    If all the fans are exposed to outside air (vented) they will cool all the components sufficiently.
    Equipping the enclosure with a digital thermometer will cost less than three dollars.
    LCD Display Digital Panel Be Mounted Thermometer with Metal Sensor for Testing | eBay
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    May 2014
    19
    Thanks, I made a mistake. They are 10A not 16. So I need both.
    Jun 2004
    6618
    Is the top PS vented through the case? If not, it should be or it needs more room between it and the case.
    Don't forget to filter the inbound air supply.
    Lee
    35538
    To add to what Lee said.
    The fan blowing out should be at the top.
    If this is for a router, you better have some really good filters over the intake fans, or you'll have a box full of dust. It seems that in 95% of the pics I see, filtering the intake air is not a consideration. I use automotive air filters over my intake fans, and they keep the box spotless. They're cheap, too.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2014
    19
    The PS have their own fan build in, one of them is pointed outside through a hole in the box. I put the fans on the outside of the box. Got to figure out a good way to filter the air. Don´t want to obstruct the air flow to much either.
    Feb 2007
    4553
    Lightbulb Re: Do you think this will be cool enough?
    Spooner777,
    Search eBay for "cabin air filter" or "engine air filter" there are many types that would be simple to attach to your enclosure.
    New Engine Air Filter for 2009 2012 Acura TSX 2 4L 4 Cyl 17220 PL5 A00 AF6061 | eBay
    Jeff...
    May 2014
    19
    Quote Originally Posted by jalessi View Post
    Spooner777,
    Jeff...
    Thanks!
    - - - Updated - - -
    I guess I could just connect the 3 fans in series and power them off the 36volts power supply? Or should I get an extra adapter?
    Feb 2007
    4553
    Spooner777,
    Why not attach the fans to the P.C. 12 volts?
    Running the three fans in series would pose an issue if one fan failed (opened circuit), the remaining fans would lose power.
    Most likely you would not notice the fan stoppage until a overheat condition causes a more serious issue.
    See attach image of P.C. power connection pinout.
    Jeff...
    May 2014
    19
    Yeah, but where do I get the PC power supply from? Got no space left. Maybe Ill find a simple 12 volt adapter in the garage that I can use.
    Feb 2007
    4553
    Lightbulb Improvise, adapt and overcome.
    Spooner777,
    99.9% of most hobby CNC machines require a P.C. to run them (Mach3... Linux CNC... etc...) and have 12 volts and 5 volts readily available.
    Five minutes to open the P.C. case and attach a external 12 volt power connection would be a cinch.
    Jeff...
    Feb 2007
    966
    Is that a wooden box ? No, don't do that. get a metal box.. Thats just wrong
    Jun 2014
    4
    Jan 2012
    201
    all fans on 1 side of the box all blowing out
    filter on other side of box set in to a hole cut to match its size
    Jul 2014
    2
    You gave your full effort.....good one.
    Jul 2014
    2
  1. Replies: 0
    Last Post: 01-21-2014, 06:07 AM
  2. Replies: 0
    Last Post: 01-14-2014, 05:50 AM
  3. Oh.. this is cool...
    By murphy625 in forum Community Club House
    Last Post: 06-15-2005, 01:39 AM
  4. want to see something very cool
    By Stevie in forum Uncategorised MetalWorking Machines
    Last Post: 02-10-2005, 01:22 PM
  5. cool vid
    By nervis1 in forum Community Club House
    Last Post: 02-10-2005, 05:28 AM
