587,126 active members*
3,029 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Importing 3D stock into Visual Mill 6.0
Results 1 to 9 of 9
    Jul 2013
    6
    Can anyone provide information on how to import a 3D stock material blank into Visual Mill 6.0 and have it called up as stock and not a part object?
    Sep 2009
    38
    Quote Originally Posted by Boxey45 View Post
    you can import more than one solid and just put them on separate layers. Would that work? I'll see if 2012 supports that custom stock in the morning
    Jan 2004
    3154
    Been awhile since i have done it. But this will get you started. Make a stock model in cad and import in vm. Then i believe that you do save-as stock model (if this is not am option then maybe it was stl but there must have been some reason why i used to do it in vm instead of sw). It was easy to do. Call mecsoft if you need an answer. I am on holiday.
    www.integratedmechanical.ca
    Sep 2009
    38
    OK I'm at work now, there's an export stock as STL feature, but no import for "custom" stock. I'd just do two layers if you need something else. I can't imagine what you're trying to do otherwise. I mean, everything starts with a cube or if it's a casting / custom thing just ignore creating stock for it. Maybe you can explain more of what you're trying to accomplish or the challenge you are facing with the part?
    Jan 2004
    3154
    In vm6 you can't just shove a model on a layer and call it stock.
    Stock models must be stls as you have verified for me. There are many reasons to need stock models. Most 3d machining is calculated from the stock model. I had some intricate "horn looking" parts that came out of the lathe and into my forth axis. Without a stock model i would have spent many days of my toolpath cutting air for stock that didnt exist. As it was my spindle time was almost 200 hours.
    Sep 2009
    38
    No as i said you can't import an stl as a stock model.
    Jan 2004
    3154
    It must have been VM5 that I was doing the stock import in then.
    Just pissing around with it in 6 and not finding that feature.
    If you get and answer from Mecsoft on how it is down, please share it with us
    Jul 2013
    6
    Thanks to everybody for the input. As soon as I find a method, I will post the results.
    Dec 2013
    Re: Importing 3D stock into Visual Mill 6.0
    When you have Visual Mill 6 Pro, you can use the command Stock from Selection it is only in the Pro version.
  1. Visual Mill 6.0
    By ibrich in forum Visual Mill
    Last Post: 08-14-2014, 09:48 PM
  2. Visual Mill 5.0
    By gda in forum Visual Mill
    Last Post: 12-07-2011, 04:17 PM
  3. Visual Mill (as CAD)
    By John Gamble in forum Visual Mill
    Last Post: 02-08-2011, 09:38 PM
  4. Bob CAD or Visual Mill
    By nandomax in forum Uncategorised CAM Discussion
    Last Post: 05-25-2007, 02:55 PM
  5. Need help with VISUAL MILL
    By replicapro in forum Visual Mill
    Last Post: 06-18-2006, 04:06 PM
