587,188 active members*
4,841 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > I may have under sized my gantry beam.
Page 1 of 4 123
Results 1 to 20 of 73
    Mar 2011
    357
    I am building a 4x8 CNC router. My gantry beam is a 65 inch length of 3x4x.125 steel tube. I am using the CNCrouterparts linear rail so I have bolted and epoxied a length of 4x.250 CRS plate to the 3 inch wide side which is the vertical axis. I am beginning to think that this tube, even with the .250 CRS plate glued to one side may not resist twisting as well as I had hoped.
    I am hoping to put a 2.2kw spindle on it.
    So I have two questions.
    Is this beam strong enough?
    If not, would welding a length of 2.5x2.5x.375 steel angle across the rear vertical surface fix the issue?
    See attachment.
    ThanksClick image for larger version.
    May 2005
    3920
    Re: I may have under sized my gantry beam.
    It is likely marginal but a lot depends on additional information. One piece is what do you expect to machine The second is how high are you in Z. Perhaps most important is what are your expectations out of this machine.
    As for the angle iron if you do have a problem I wouldn’t try to correct it this way. Most likely I would just buy another beam of larger cross section. In any event I wouldn’t stress over it until you have considered how the machine will be used. I can see a machine with such a gantry beam as being usable in a number of circumstances. However if your goal is to push the machine hard in difficult materials and at the same time expect high quality you likely will not be happy.
    Mar 2011
    357
    OK I have about 6 inches travel in my z axis. I want to route aluminum but I wouldn't mind building a raised table for this to reduce the z twisting radius.
    If that is no good, My beam needs to be 3 inches in the vertical axis but could be larger than 4 inches in the horizontal. How thick of material do
    I need to make this work?
    Dec 2013
    5714
    As I recall a MultiCam 5x10 router has a 6x10x0.25 wall gantry beam. My 4x8 router had a 10x10x0.375 wall gantry beam. Both have about 6 inch Z
    Not sure why you are limited to 3 inch in the vertical, you could always space the rail off of the beam a bit for clearance if needed.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2018
    29
    I probably would have gone with a thicker material, but why not try it as-is? You might be ok with it.
    If it does let you down, then you’ll be able to interpret better what is wrong and then apply a better, more directed fix.
    Feb 2005
    829
    You could possibly reinforce the beam with a X pattern of material down the inside of the existing beam.
    Jun 2004
    6618
    It will flex and flex alot. Especially in the middle. It isn't really worth the effort to try and beef it up. It would be fine for a plasma cutter, but not for a machine with cutting forces. I don't think twist is the only concern. Up and down flexing would be just as bad.
    I would honestly start over.
    I have about a 5' wide gantry on my plasma cutter. It also uses a die grinder for engraving. I have used it to machine polycarbonate before as well. While I did get usable results, they were not perfect. The depth was a little hard to control and required a finish pass. I was using straight flute bits too. If I were to use a cutter with a helix, it would actually push or pull the tool deeper than wanted.
    My gantry beam is 3" x 3" aluminum extrusion with the 1/4" x 4" flat steel bar bolted to it. It works great at plasma cutting and engraving. Lots of easy speed.
    Not optimal as a router.
    I don't think I would rely on adhesive only for a structural joint either. I would back it up with at least a few mechanical fasteners. Especially given that this beam will be flexing.
    Lee
    Mar 2011
    357
    Well I have to admit I never thought that .25x4 plate would flex in the verticle. CNCRouterparts makes their 4x8 on a 3x3 chunk of 8020. Maybe that is a lot stronger. I looked at speedy metals for a 5x5x.25 tube and the price was over $300. I have to find a cheaper way. Thanks for all your input.
    May 2005
    3920
    Quote Originally Posted by tkms002 View Post
    How much flex you get will be a direct function of how you use the machine. In this case it isn’t so much as flexure in one direction but rather the combination of flex in all directions and twist. If you are this far along you might as well finish the build. Since “machine aluminum” means different things to different people you can always try and see if it meets your expectations.
    As for extrusions do not assume that they are stronger or even a good solution. More so You can’t rely upon the opinion of others as we comeback to the question of what it means to machine aluminum and what your expectations are.
    As for steel beams don’t buy from online vendors known for jacking up the prices few to the extreme. Find a local steel supplier and get your metals at more reasonable prices. If you are in the Rochester NY area, Klein is moving their metal outlet store where they sell a lot of drops, due to the move stuff is going at a discount. In not sure what the discounted price will be but they expect to be gone by the end of the month and setup in a new facility. Of course there is the issue of luck and the right beam being there.
    For what you are talking about here, an ideal steel beam would be at least 8x8 inches and relatively thick. The thickness is more about screw holding and machining allowance than anything. In any case the beam itself needs bracing to prevent it from going parallelogram like under load and to help resist twisting.
    There is a sticky thread that goes deeply into gantry beam design that would box be well worth reading.
    Feb 2005
    829
    CNCRouterParts uses a 160mmx80mm about 6inch x 3inch aluminum extrusion.
    Mar 2011
    357
    Quote Originally Posted by nlancaster View Post
    the new ones do, yes. But at the school I mentored a robotics club at we bought one several years ago (a 4848) and it has a 3x3 gantry beam.
    Jun 2004
    6618
    The 3x3 heavy extrusion is quite a bit stiffer than the 1/8 in wall tube by itself. It has the added benefit of all the inner webbing to help support it.
    Lee
    May 2005
    3920
    Quote Originally Posted by LeeWay View Post
    This likely should be qualified a bit as there are huge differences in extrusions from one manufacture to another. Even what is considered to be a heavy extrusion varies a bit.
    Feb 2005
    829
    I have never seen a CNCROuterparts that used less then 3x6inch beam for the 4ft axis, they had plans for a machine that was 24x36 with a 3x3 beam. And I have been reading about cncrouterparts since he started by just making and selling his skate bearing units.
    Mar 2011
    357
    Well, we have one at Arrowhead High School in Hartland Wi.
    Mar 2011
    357
    OK I stand corrected. It was not a CNCRouterpars kit. It was a FineLineautomation kit using CNCRP parts.
    My apologies
    Jun 2004
    6618
    Cost can certainly be an issue. You might want to proceed with the build and upgrade later.
    You can setup an easy test to see what you have. Support the beam on both ends.
    Put a dial indicator in the middle. Then add a little weight. I think you will be surprised by how much movement you see.
    Lee
    35538
    Speedy metals is expensive.
    You can get a 3/16 4x6 for a lot less.
    https://www.onlinemetals.com/merchan...41&top_cat=849
    Regardless, you'll want to reinforce the beam, maybe like this one.
    https://www.cnczone.com/forums/cnc-w...ml#post1689518
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2004
    6618
    I designed my plasma cutter the same way. It does use CRP trucks and drive components. The First design they had uses roller skate bearings on flat bar rather than V wheels and later profile linear rails and trucks.
    Lee
    Jun 2004
    6618
    This was what I call the standard. 80/20, but I know there are many sources. But when discussing CRP machines, they use 80/20 exclusively as far as I know.
    80/20 has a light version extrusion and what I call heavy. My term. If one is light/lite, then a thicker extrusion in similar dimensions would be heavy.
    I haven't seen anything CRP related that uses a lite variety of extrusion.
    Lee
Page 1 of 4 123
  1. Replies: 2
    Last Post: 10-18-2018, 03:28 AM
  2. 80/20 Gantry Beam Prototype
    By Jkountz in forum DIY CNC Router Table Machines
    Last Post: 09-18-2014, 07:56 AM
  3. Router Gantry Beam strenght and vibration?
    By Knut in forum DIY CNC Router Table Machines
    Last Post: 12-27-2010, 06:29 PM
  4. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
