587,743 active members*
3,117 visitors online*
Results 1 to 2 of 2
    Apr 2009
    60
    GRBL and Gecko G540
    Hi team
    Hoping the team might be able to give me some guidance on my new setup.... Finally after about 8 years of running Mach 3 my computer has gone bang and is no more!
    I knew this day would come so I've been looking at a replacement option, didn't want to do it earlier as I've just become so familiar with Mach 3.
    Anyway found Ultimate CNC for GRBL that looks like something I could try. My old system used the Gecko G540 driver and a USB RS452 (??) converter to run the VSD, all ran very nice.
    I've just connected the G540 to my Arduino board and axis travel is as it should be, the question now is spindle control. The G540 has 0-10v output for driving a VSD, the Arduino has 0-5v output so can I connect the Arduino to the G540 to get full spindle control? Or do I need a stand alone PWM board to lift the 5v to 10v?
    Would really appreciate any guidance you can give on this one.
    Cheers Dave
    Mar 2015
    413
    Re: GRBL and Gecko G540
    5V output to the VFD is no problem. You can set the VFD to run at full speed on a 5V input signal.
    The Arduino output is a 5V PWM signal. Your VFD probably won't like this signal. I am going to use a PWM to voltage converter. Mine have a 78M12 power regulator so it can be safely powered by 24V.
    https://nl.aliexpress.com/item/10050...d=rRQVhplfDTQa
  1. Replies: 1
    Last Post: 08-27-2018, 08:41 AM
  2. Gecko G540 9x
    By minsk in forum DIY CNC Router Table Machines
    Last Post: 09-27-2016, 08:52 PM
  3. Gecko G540
    By malgazz in forum South Africa Club House
    Last Post: 10-25-2015, 10:02 AM
  4. Replies: 1
    Last Post: 01-03-2014, 08:58 AM
  5. Gecko G540
    By rotger in forum Servo Motors / Drives
    Last Post: 06-02-2009, 06:43 PM
