587,481 active members*
3,237 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Machining Configurations
Results 1 to 5 of 5
    Sep 2013
    15
    How can I change Machining Configurations in an existing Featurecam program?
    Jul 2011
    218
    i would think go to manufacturing machining configs then it should have a config with the file name
    ive got mine set just how i like and if you have your speeds n feeds set up with ur mat library like i do the only thing i have to do is select my tool and its done
    CHOCLATE? THIS IS DOODOO BABY!
    Sep 2013
    15
    If I program a part for aluminum and later want to do the same part in tool steel I want to change to a different Machining Configuration. I am not able to change the Machining Configuration to anything else in an existing file.
    I see it can be done with Delcam For SolidWorks but I do not see how it can be done for Featurecam.
    https://www.youtube.com/watch?v=iFuHOuvxaks
    Jul 2011
    218
    i would just open the file
    part view
    stock and just change materials from alu to tool steel
    speeds and feeds are set up in the material library
    depths of cut, leads, finish allowances are in machining attributes
    you might have to set up a different machining config for harder materials and also swap that out with the material data
    Mar 2006
    31
    Changing your Material and/or Machining Attributes will change your default settings. If you made any changes while writing the program, those will not change. Youll have to manually change them again. Anything with an * next to it in your properties, or speeds and feeds that have the override checked, have been changed manually.
  1. configurations
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-25-2012, 11:03 PM
  2. First SolidCAM part, configurations
    By ASPIDesign in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-01-2011, 04:19 PM
  3. Materials and configurations
    By nbgx3 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-23-2007, 10:10 PM
  4. Importing Solidworks parts with configurations.
    By moldmker in forum BobCad-Cam
    Last Post: 02-04-2007, 11:41 PM
  5. please tell me the wire configurations of this
    By shaiqbashir in forum Stepper Motors / Drives
    Last Post: 04-12-2006, 09:41 PM
