587,180 active members*
3,870 visitors online*
IndustryArena Forum > CAM Software > Esprit > Work Planes / Work Coordinates
Results 1 to 12 of 12
    Jan 2007
    8
    Esprit 2007
    Anybody ever get an error "Can't reach this position (needs another axis of rotation)."
    Work Coordinates are calling up the correct work planes and every thing seems to be fine looking at the program manager in detail. When I run the simulator I get the above error.
    If I post the NC code and backplot it, the code has the tool dropping in from what the original origin, before I rotated it and made a different work plane. In this case the from the bottom of the screen up. No wonder it wants another axis of rotation.
    V/R
    MICFDI
    Feb 2007
    158
    Either your machine set-up does not have all the axis defined, or defined correctly, or you do not have the correct software package!
    I hate deburring.....
    Lets go (insert favorite hobby here)
    Jan 2007
    8
    I should have been a bit more clear on the problem.
    If I am using X, Y, Z coordinates everything works fine. It is only when I change the work plane, do I experience the problem.
    V/R
    MICFDI
    2932
    What type of machine are you programming? VMC, HMC, Multi-axis lathe?
    Jan 2007
    8
    HAAS - VMC
    3 axis stuff only.
    V/R
    MICFDI
    2932
    MICFDI...
    Check your PM's.
    2932
    I only have E2008, so I can't send you a modified file... sorry.
    Your Op1 Workplane is upside down. Since your machine doesn't have a "B" (rotary) axis, Esprit can't reach the processes on Op1, hence the error when you simulate. You need to have all your Z's pointing up. Do the part in two different Esprit files or move Op 2 off to the side and flip the part over to keep Z pointing up (as it is on your machine).
    Good luck.
    Jan 2007
    8
    Thank you for your time / help - much appreciated.
    V/R
    MICFDI
    May 2008
    10
    esprit users
    Hey do any of you esprit users program Mori's NT style machines?
    Looking for information on esprit and how easy it is to use..
    Feb 2007
    158
    Not an NT, but I use it on both and NV and an NLY. The only problems I have had our me not taking the time to get the posts right. Once your posts are set up, it works great.
    Dec 2007
    48
    Re: Work Planes / Work Coordinates
    Quote Originally Posted by MICFDI View Post
    Esprit 2007
    im having the same problem i made a new work plane on side of part uvw in right place but when i go to render it says i need another axis of rotation can anyone help with this im new to esprit
    Sep 2008
    18
    http://www.cnczone.com/forums/esprit...ml#post1569952
    I just answered this same question at the above link
  1. Yasnac MX2 work coordinates.
    By PHD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-15-2021, 09:21 PM
  2. How do you set your X & Y work coordinates?
    By RicknBeachcrest in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 08:51 PM
  3. How to use work coordinates
    By desellers in forum Haas Lathes
    Last Post: 06-24-2013, 02:28 AM
  4. multiple work coordinates
    By cinomarra in forum CamWorks
    Last Post: 03-19-2013, 03:17 PM
  5. Okuma Work Coordinates
    By firedog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2005, 12:43 AM
