587,935 active members*
4,210 visitors online*
Results 1 to 14 of 14
    Jun 2008
    7
    Unhappy Error on Fagor 8055
    Can anyone help me figure out how to fix "1102 X Axis following Error" ???
    Dec 2003
    24220
    Following error is generally the axis cannot keep up with the commanded move, is the axis moving? Does it Jump suddenly or not move at all?
    Do you have 'Following Error Display' screen on this model ?
    Al.
    Albert E.
    Jun 2008
    7
    The axis, In this case "X", will stop in the middle of a program. I will get the error message and will have to reboot the machine to get the axis to move. Last night i adjusted the transformer on that axis and was able to finish a program with out a problem. I am still unsure if i resolved the problem. What should the following error be set at? I am set at .0293 right now.
    Dec 2003
    24220
    Quote Originally Posted by carving123 View Post
    Is this the set value or the reading of the Detected amount of FE?
    The degree of setting amount will depend a lot on the type of machine and the tuning.
    Test for tightness if it occurs at one spot etc.
    You could increase the allowed following error value or try tuning the axis with a slightly more gain.
    Al.
    Albert E.
    Apr 2006
    187
    Maintenance???
    MotionMaster and Western CNC use Fagor 8055, if your machine is one of these it may be wise to remove the ball screw cover and check the ball screw. Have seen this error on these machines when they are in dire need of cleaning, grease.....etc. X axis on these machines require weekly maintenance. Check belts, ball nut etc.
    Dec 2007
    617
    The following error is not "set" ideally the following error would be 0, however that's not possible. Any time a machine starts to fault out on this kind of parameter, you need to check the basics (loose wires, etc.), before jumping in to the parameter table.Software doesn't just change. Mechanical stuff does.
    Have a read...
    http://www.fagor-automation.com/CNC/...Axis_Setup.pdf
    PS write down the old values before making changes, and change 1 parameter at a time.
    cheers
    Can't Fix Stupid
    Dec 2007
    617
    More info....
    cheers
    Attached Files Attached Files
    Can't Fix Stupid
    Dec 2003
    24220
    Quote Originally Posted by cam1 View Post
    I did not mean that the following error is set, I was referring to the following error Value that is allowed to occur before excess following error is detected and acted on.
    Al.
    Albert E.
    Dec 2007
    617
    Hi Al: I was referring to the comment by carving 123 that you quoted.
    regards
    Can't Fix Stupid
    Jun 2008
    7
    Thanks, You were very helpful. Problem solved!!
    Apr 2006
    187
    Curiousity.......what was the solution?
    Jun 2008
    7
    Tightened all the wire conections and clean and lubed all guide bearings and cleaned both lead screws. No problems since.
    Jan 2010
    2
    can anyone help me figure out how to fix "delected error N=32, CNC: gen_blog (00001 CAC). press key
    Jan 2010
    2
    help me!
    fagor error
    can you help me figure out how to fix " delected error N=32, CNC: gen_blog (00001 CAC). press key
  1. Fagor 8055 or Haas CNC control?
    By Angry Man in forum Fagor Automation
    Last Post: 03-31-2020, 02:22 AM
  2. Fagor 8055 Mill won't home
    By cam1 in forum CNC Machining Centers
    Last Post: 03-05-2008, 02:39 AM
  3. Fagor 8055 power down/switch off
    By smoregrava in forum Fagor Automation
    Last Post: 01-02-2006, 01:32 PM
