Hello, I'm working on building my first 4 axis C&C Mill. Currently I have acquired two 22 inch(travel) kuroda precision ground ballscrews that have 10 mm pitch. And one 8 inch long kuroda z axis ball screw with the 5 mm pitch. *All are 15mm thick. *I will be milling aluminum and plasma cutting as well. I'm using THK linear slides and hoping to acquire some 8020 extrusions for my chassis. *
I've decided to use stepper motors due to the ease of implementation and cost effectiveness. After doing some research on the cheaper motors found available on eBay by various companies like Wantai motor and Long's motor. I noticed that the inductance is a little bit higher than the American equivalents produced by companies like Keling. *I was considering some of their 1600 ounce inch nema 34 motors they had for sale but noticed that the inductance was 22 mH. *Do you think a motor that size is bound to be slow? The company's representative said that advancements in their new digital drivers provided for faster speeds. *
I called Keling and spoke to one of their representatives. They said that for my application even a 570 ounce inch motor would be too big. They recommended something more along the lines of 300 ounce inches. They also stated that their new digital drivers could achieve over 180 ipm. *but if I wanted to achieve higher speeds I needed bigger motors. *
I guess my questions are these. *Are bigger motors still faster if the inductance is higher like the 22mh 1600 oz in. Chinese motors. Or are smaller American made motors with lower inductance better for my application and also capable of providing higher speeds due to lower inductance? *Would I be better off speed wise buying motors and using a gecko 540 driver instead?
The Chinese motors are over three times the torque at the same price. *I don't know if there is some hidden cons to their products. *Thanks for listening
