587,240 active members*
3,136 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Biesse Rover 30 Z axis motor wiring
Results 1 to 2 of 2
    Jan 2023
    2
    Hey everyone, hope someone can help me. We had to order a new motor for our z axis and have question on 2 black wires that need to connect to terminals.
    These 2 black wires are not labelled on new motor and look like about a number 18 gauge wire. They were same on old but not labelled on old motor either. There is 2 wire terminals that these black wires get inserted and tightened into.
    Also here is image of wiring diagram.
    Thanks in advance.
    Mar 2024
    3
    Re: Biesse Rover 30 Z axis motor wiring
    These two wires connect the 24V to the brake of the Z-axis to make it open. If you don't connect them the drive will show an overload alarm because the motor shaft is braked by default and needs 24V to open the brake. Please send me the wiring diagram of this machine.
    Thanks and regards,
    Omar
  1. Biesse Rover A 2007 , axis C1 not homeing
    By bartoshdg in forum Biesse
    Last Post: 02-28-2021, 10:49 AM
  2. Biesse Rover A 2007 , axis C1 not homeing
    By bartoshdg in forum CNC Machining Centers
    Last Post: 02-19-2021, 11:37 AM
  3. Biesse rover 23: Z axis unaccurate
    By ludovic815 in forum CNC Machining Centers
    Last Post: 10-31-2016, 07:42 PM
  4. Biesse Rover 322 : X axis not working
    Last Post: 06-28-2016, 07:09 PM
  5. Biesse Rover 5 Axis Operator Wanted
    By nigjoe in forum Employment Opportunity
    Last Post: 08-22-2012, 04:32 PM
