If you don't have a light for your machine or want to add a second light and are put off by the $395 listed price, www.jarrer.com is who makes the lights used in the Hurco's. They can be had from http://www.rasmachinetool.com (which has been easy to deal with) for $135 for the JW-70RTM. http://www.rasmachinetool.com/catalo...products_id=34
They are a direct bolt in, 70W halogen, IP65 rated and come with the hardware. You'll need to chop off the standard 110V plug if you want to plug it into the outlet on the Hurco, you can pick up the IEC C14 right angle male connector from www.digikey.com for a sum of $4, it's part number 708-1353-ND
No affiliation with either supplier, just trying to save a buck where I can like everyone else. Looked at Waldmann, and Electrix and scoured Ebay for weeks until I ran across the info I was looking for.
