587,082 active members*
2,824 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How download parameters FANUC-18T via RS232
Results 1 to 5 of 5
    Hi!
    I have BIGLIA 501 with FANUC-18T. I can not make SRAM dump via PCMCI card due to "Pariry Error". I want to download parameters via RS232 interface.
    What programm to use? Are there any FANUC native program to do it?
    Dec 2009
    967
    Re: How download parameters FANUC-18T via RS232
    there are many software to download but i use from long time CIMCO EDIT for transmission
    Apr 2009
    1379
    If the SRAM backup in BOOT mode results in a parity error, you will likely also get that when downloading the programs. Try deleting the offending program and then do the SRAM backup.
    Aug 2009
    1573
    ...try changing "Bit Parada" to 1 or 0
    DJ
    May 2016
    26
    Could you solve the problem?
    I’m using COMMUNICATION SOFTWARE FOR FANUC CNC with the same FANUC CNC.
    It is specially designed for FANUC CNC though it can be used also with other CNC.
    It has several built-in help menus that show you how to use it with your CNC.
    You can download it from “The SOFTPEDIA· web page.
  1. Replies: 2
    Last Post: 05-05-2019, 11:12 AM
  2. fanuc 18t parameters editting peocedure
    By VENKATESH REDDY in forum Fanuc
    Last Post: 09-27-2010, 01:26 PM
  3. Fanuc 18T-A Parameters-Nakamura T.C.
    By JerryH in forum Fanuc
    Last Post: 07-02-2008, 12:42 PM
  4. Replies: 2
    Last Post: 02-15-2007, 03:10 AM
  5. Fanuc 18T - Parameters
    By pinguS in forum Fanuc
    Last Post: 04-12-2006, 12:20 AM
