587,507 active members*
2,651 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HAAS renishaw probing subroutines
Results 1 to 6 of 6
    Nov 2016
    4
    Can anyone provide me the P9810, P9811 & P9812 renishaw subroutines used for probing on HAAS VF4 to do the simulation of probing NC program in Vericut.
    Thanks,
    Sujay
    Nov 2006
    490
    Re: HAAS renishaw probing subroutines
    I copy/pasted those three programs below. Look between the percent signs.
    Note that the programs are functionally identical between different revisions of the probe programs, so they can be interchanged regardless of the machine year.
    O09810 (REN PROTECTED POSN)
    G103 P1
    #3001= 0
    G04 P250
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    IF [ #3001 LT 200 ] GOTO999
    G65 P9724
    IF [ #9 NE #0 ] GOTO3
    IF [ #167 NE #0 ] GOTO2
    #3000= 88 (NO FEED RATE)
    N2
    #9= #167
    N3
    #167= #9
    #198= 0
    N4
    G31 X#24 Y#25 Z#26 F#9
    IF [ #24 EQ #0 ] GOTO5
    IF [ ABS[ #5041 - [ #24 ] ] GT #173 ] GOTO8
    N5
    IF [ #25 EQ #0 ] GOTO6
    IF [ ABS[ #5042 - [ #25 ] ] GT #173 ] GOTO8
    N6
    IF [ #26 EQ #0 ] GOTO7
    IF [ ABS[ [ #5043 - #166 ] - [ #26 ] ] GT #173 ] GOTO8
    N7
    GOTO9
    N8
    #198= 7.
    IF [ #13 EQ 1. ] GOTO9
    #3000= 86 (PATH OBSTRUCTED)
    N9
    N999
    G103
    M99
    O09811 (REN XYZ MEASURE)
    G103 P1
    #3001= 0
    G04 P250
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G65 P9724
    IF [ #19 EQ #0 ] GOTO1
    IF [ #20 EQ #0 ] GOTO1
    #3000= 91 (ST INPUT MIXED)
    N1
    IF [ #19 EQ #0 ] GOTO2
    IF [ #11 EQ #0 ] GOTO2
    #3000= 91 (SH INPUT MIXED)
    N2
    IF [ #20 EQ #0 ] GOTO3
    IF [ #13 EQ #0 ] GOTO3
    #3000= 91 (TM INPUT MIXED)
    N3
    #1= 185
    WHILE [ #1 LE 199 ] DO1
    #[ #1 ]= #0
    #1= #1 + 1
    END1
    #10= #5041 (X START)
    #12= #5042 (Y START)
    G31 X [ #10 - #[ #161 + 2 ] ] Y [ #12 - #[ #161 + 3 ] ] F#169
    IF [ ABS[ #5041 - [ #10 - #[ #161 + 2 ] ] ] GE #173 ] GOTO22
    IF [ ABS[ #5042 - [ #12 - #[ #161 + 3 ] ] ] GE #173 ] GOTO22
    #30= -1 (DIR FLAG)
    IF [ #24 NE #0 ] GOTO5
    IF [ #25 NE #0 ] GOTO7
    (Z MOVE)
    IF [ #26 EQ #0 ] GOTO225
    #7= 5203
    IF [ [ #5043 - #166 ] LT #26 ] GOTO4
    #30= 1
    N4
    G65 P9726 Z#26 Q#17
    IF [ #199 NE 0 ] GOTO21
    #185= #10
    #186= #12
    #187= #176 - #166 (Z POS)
    #188= #187
    IF [ #8 EQ #0 ] GOTO45
    #188= #188 + #[ 2000 + #8 ] (SIZE)
    N45
    #192= #187 - #26 (Z ERROR)
    #193= #188 - #26 (SIZE ERROR)
    #195= ABS[ #192 ] (T P ERR)
    #196= #193 * #30 (METAL CON)
    GOTO9
    N5 (X MOVE)
    IF [ #25 NE #0 ] GOTO225
    IF [ #26 NE #0 ] GOTO225
    #6= #[ #161 ]
    #7= 5201
    IF [ #5041 LT #24 ] GOTO6
    #6= - #[ #161 ]
    #30= 1
    N6
    G65 P9726 X#24 Q#17 S #[ #161 ]
    #185= #174 + #6 + #[ #161 + 2 ] (COR SKIP POS)
    #186= #12
    #188= #185
    IF [ #8 EQ #0 ] GOTO65
    #188= #188 + #[ 2000 + #8 ] (ACT SIZE)
    N65
    #190= #185 - #24 (X ERROR)
    #193= #188 - #24 (SIZE ERROR)
    #195= ABS[ #190 ] (T P ERROR)
    GOTO9
    N7 (Y MOVE)
    #6= #[ #161 + 1 ]
    #7= 5202
    IF [ #5042 LT #25 ] GOTO8
    #6= - #[ #161 + 1 ]
    #30= 1
    N8
    G65 P9726 Y#25 Q#17 S #[ #161 + 1 ]
    #185= #10
    #186= #175 + #6 + #[ #161 + 3 ] (Y SKIP POS)
    #188= #186
    IF [ #8 EQ #0 ] GOTO85
    N85
    #191= #186 - #25 (ERROR)
    #193= #188 - #25 (SIZE ERROR)
    #195= ABS[ #191 ] (TP ERROR)
    N9
    #197= #30
    IF [ #23 EQ #0 ] GOTO10
    G65 P9730 H#11 M#13 S#19 T#20 W#23 X#24 Y#25 Z#26
    N10
    IF [ #21 EQ #0 ] GOTO11 (U UPPER TOL)
    IF [ ABS[ #193 ] GE #21 ] GOTO23
    IF [ #195 GE #21 ] GOTO23
    N11
    IF [ #11 EQ #0 ] GOTO13
    IF [ ABS[ #193 ] LT #11 ] GOTO12
    #198= 1
    N12
    IF [ #170 AND 4 EQ 4 ] GOTO13
    IF [ ABS[ #193 ] LT #11 ] GOTO13
    G00 X#10 Y#12
    #[ 3006 - [ [ #170 AND 8 ] / 8 * 6 ] ]= 1 (OUT OF TOL)
    N13
    IF [ #13 EQ #0 ] GOTO15
    IF [ ABS[ #195 ] LT #13 / 2 ] GOTO14
    #198= 2
    N14
    IF [ #170 AND 4 EQ 4 ] GOTO15
    IF [ ABS[ #195 ] LT #13 / 2 ] GOTO15
    G00 X#10 Y#12
    #[ 3006 - [ [ #170 AND 8 ] / 8 * 6 ] ]= 1 (OUT OF POSITION)
    N15
    IF [ #20 EQ #0 ] GOTO19
    IF [ ABS[ #196 ] LT #22 ] GOTO19 (NULL BAND)
    IF [ #9 NE #0 ] GOTO16
    #9= 1
    N16
    G65 P9732 T#20 C [ #196 * #9 ] Z#26
    N19
    IF [ #19 EQ #0 ] GOTO24
    G65 P9732 S#19 Z#26 W1.
    GOTO24
    N21
    IF [ #199 NE 2 ] GOTO22
    G00 X#10 Y#12 (return to start)
    #3000= 93 (PROBE FAIL)
    N22
    G00 X#10 Y#12
    #3000= 92 (PROBE OPEN)
    N225
    G00 X#10 Y#12
    #3000= 91 (XYZ INPUT MIXED)
    N23
    #198= 3
    IF [ #170 AND 4 EQ 4 ] GOTO24
    G00 X#10 Y#12
    #[ 3006 - [ [ #170 AND 8 ] / 8 * 6 ] ]= 1 (UPPER TOL EXCEEDED)
    N24
    G00 X#10 Y#12
    N999
    G103
    M99
    O09812 (REN WEB POCKET MEASURE)
    G103 P1
    #3001= 0
    G04 P250
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G04 P1
    G65 P9724
    N1
    IF [ #24 EQ #0 ] GOTO2
    IF [ #25 EQ #0 ] GOTO2
    #3000= 91 (XY INPUT MIXED)
    N2
    IF [ #24 NE #0 ] GOTO3
    IF [ #25 NE #0 ] GOTO3
    #3000= 91 (XY INPUT MISSING)
    N3
    #1= 185
    #[ #1 ]= #0
    #1= #1 + 1
    END1
    #30= -1
    IF [ #26 EQ #0 ] GOTO6
    IF [ #18 NE #0 ] GOTO5
    #18= 5 * #179
    N5
    IF [ #18 LT 0 ] GOTO6
    #30= 1
    N6
    IF [ #25 EQ #0 ] GOTO7
    #7= #25
    G65 P9722 D#7 Q#17 R#18 Z#26 S #[ #161 + 1 ]
    G00 X#10 Y#12
    #186= #178 + #[ #161 + 3 ] (Y COR POS)
    #188= [ ABS[ [ #175 - #178 ] * 2 ] ] - [ #[ #161 + 1 ] * #30 * 2 ] (SIZE)
    #188= #188 + #[ 2000 + #8 ] (COR SIZE)
    N65
    #191= #186 - #12 (Y POS ERROR)
    GOTO8
    N7
    #7= #24
    G65 P9721 D#7 Q#17 R#18 Z#26 S #[ #161 ] (X MOVE)
    G00 X#10 Y#12
    #185= #177 + #[ #161 + 2 ] (X COR POS)
    #188= [ ABS[ [ #174 - #177 ] * 2 ] ] - [ #[ #161 ] * #30 * 2 ] (SIZE)
    IF [ #8 EQ #0 ] GOTO75
    N75
    #190= #185 - #10 (X POS ERROR)
    #195= ABS[ #190 ] (TP ERROR)
    N8
    #193= #188 - #7 (ERROR OF SIZE)
    #196= #193 * #30 / 2 (METAL CON)
    N9
    G65 P9730 D#7 H#11 M#13 S#19 T#20 W#23 X#10 Y#12 E2.
    N10
    N11
    #198= 1
    N12
    G00 X#10 Y#12
    N13
    #198= 2
    N14
    G00 X#10 Y#12
    N15
    #9= 1
    N16
    IF [ #26 NE #0 ] GOTO19
    IF [ #168 LT #7 / 2 ] GOTO18
    #198= 5
    N18
    IF [ #170 AND 4 EQ 4 ] GOTO19
    IF [ #168 LT #7 / 2 ] GOTO19
    G00 X#10 Y#12
    #[ 3006 - [ [ #170 AND 8 ] / 8 * 6 ] ]= 1 (DIA OFFSET TOO LARGE)
    N19
    G65 P9732 S#19 W1.
    GOTO24
    N21
    G00 X#10 Y#12
    N22
    G00 X#10 Y#12
    N23
    #198= 3
    G00 X#10 Y#12
    N24
    G00 X#10 Y#12
    N999
    G103
    M99
    Nov 2016
    4
    Thanks for your help!!
    Nov 2016
    4
    Can you also provide me the below subroutines,
    P9726
    P9721
    P9722
    P9732
    P9724
    P9730
    Thanks,
    Sujay
    Nov 2006
    490
    I'll upload a .zip file that contains all the programs. Just select which version you need.
    If you can't open the .zip file, download the program 7-ZIP, it's the best
    Dec 2023
    1
    Quote Originally Posted by Ydna View Post
    can't find the zip file.
  1. Replies: 1
    Last Post: 10-01-2012, 06:11 PM
  2. Renishaw Probing on a 2012 Haas VM3
    By wincoaw in forum Haas Mills
    Last Post: 09-14-2012, 10:57 PM
  3. HAAS OTS Renishaw Probing Issue....
    By Doolie in forum Haas Mills
    Last Post: 09-13-2012, 02:56 AM
  4. Renishaw probing.
    By jpj1474 in forum Mach Wizards, Macros, & Addons
    Last Post: 05-02-2012, 11:18 PM
  5. renishaw probing on haas mini mill
    By kwhite2 in forum Haas Mills
    Last Post: 09-30-2010, 10:51 PM
