I'm so sorry to have to post this. I don't even know where to begin to post.
I have an MDX-15 and I've just drafted a part using my .125 flat end mill. However, after I started thinking that if I use my .032 ball end mill on a fine pass, the taper where the end mill meets the .125 shaft that goes into the collet is going to bite into my material as the part is taller than the reach of the end mill.
I'm using all the out-of-the-box software (Modela player). Is it going to be smart enough to avoid areas of cut in? (It doesn't ask for end mill reach.) Am I condemned to only machining pieces that are either within the reach of my end mill or have a curved or stepped design?
ARGH!:drowning:
