MachTechnica is a leading Bulgarian machinery dealer that trade both new and used machine tools, metal fabricating machinery, sheet metal machinery, press equipment, dealing internationally all over the world.
We are at your disposal if you need good quality used machine from the following types: Lathes, Vertical lathes, Milling machines, Grinders, Horizontal boring mills, Gear machines, Thread machines, Punch presses, Hydraulic presses, Mechanical presses, Forging presses and Forging hammers, Press brakes, Shears, Pipe benders, Plate bending machines, other Sheet metal machines, strip, tube, rod and bar making equipment, Rolling mills, Wire Machines.
You can see the availability here: https://www.machtechnica.com
