587,316 active members*
3,474 visitors online*
Results 1 to 5 of 5
    Sep 2010
    16
    Problems with HEIDENHAIN iTNC530
    I have an issue with the machine, the error was displayed once or twice but now when i startup the machine it goes to reference parameters menu and it does not allow me to start the drivers without displaying an error.I also dont hear the air valve opening and hydraulic starting as it usually does.
    Error shows in red square after it pops out of controller and it requieres a reboot.
    originally machine shows it in German and it goes :
    N76 8CA0 Referenzsignal oder strichzahl S fehlerhaft ( google translate- Reference signal or line number S faulty)
    Module: Q:/commonTNC/sources/regel/dsperror.cpp
    Line:328
    Process: REGEL
    Thread: DSPCLIENT
    Errno : 2
    Press the END key if you want to reboot the controll
    Can anybody clear this for me ,this is the only machining center in my shop and the main machine ,and as it usually goes it makes problems when you are in a tight spot!! :drowning:
    HELP
    Thanx
    Dec 2012
    36
    iTNC530 Programming Station for Windows 7
    Hello
    Thank you for entering in my post
    I am posting here since I could not find a link to open a new thread
    I do have on my old laptop with Windows 7 an iTNC530 Programming Station, which works beautifully.
    I want to have the same software on my new Desktop tower PC which also have windows 7.
    I did try to download both of these 2 programs in this link http://cid329p1338.hd45.hosting.punkt.de/?id=465 but it did work, I did try to deactivate my antivirus and turn off my firewalls before to do the download but no success
    Any suggestion according this matter will be very appreciative
    Thank you in advance for your support
    Aug 2015
    1
    Re: Problems with HEIDENHAIN iTNC530
    I have a DMG dmc835v and i got the same alarm today. How did you fix it?
    Quote Originally Posted by the-niho View Post
    Line:328
    Process: REGEL
    Thread: DSPCLIENT
    Errno : 2
    HELP
    Thanx
    Dec 2023
    10
    same error come in my machine kindly suggest the remedies for the same .i m stuck up.
    how you reolved the issue pls update me
    thanks
    Dec 2023
    10
    same error occured in my machine pls reply probable cause of above issue.we will check accordingly
    your reply is valuable for me
  1. Heidenhain iTNC530 on GROB 550
    By r_searay in forum Post Processors for MC
    Last Post: 05-22-2020, 01:43 PM
  2. HEIDENHAIN iTNC530
    By aliaghaei in forum Drilling- and Milling Machines
    Last Post: 09-10-2018, 07:52 PM
  3. Heidenhain iTNC530 cycle
    By YWKim in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2013, 05:19 AM
  4. Heidenhain iTNC530
    By Jay Roy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-07-2011, 06:31 PM
  5. Heidenhain iTNC530 First StartUp
    By Leha_Blin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-29-2008, 06:30 PM
