587,083 active members*
3,013 visitors online*
Results 1 to 5 of 5
    Mar 2019
    5
    JOES 2006 and Laptop Config
    Newbie, I'm looking at buying a Joes 2006 (10 years old). It appears, I need Mach3 software and the requirements say Laptop is not support. Is there a work around or are todays (newer than 5 years able to work with M ach3. I'm not sure if this is needed but the Stepper motors are probotix ht23-400-8.
    Sam
    35538
    Re: JOES 2006 and Laptop Config
    Newer laptops are even less likely to work, and they won't have a parallel port.
    You can use an ethernet or USB motion controller with Mach3, which will work fine with a laptop.
    I would not buy Mach3 today, as I consider it obsolete.
    I'd go with UCCNC, which is very similar, and superior in many ways. You'll need a UC100 or UC400ETH motion controller.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2019
    5
    So I assuming Stepper motors are probotix ht23-400-8 will work with UCCNC and UC400ETH motion controller. CNC4PC has UC400ETH motion controller and UCCNC license file bundle software bundle ($148.91 + $55.00) $203.91. What file format will it accept to UCCNC software? Is any other software or hardware required? The ethernet connection connect to laptop. So servo motors connect to a motherboard that has a parallel connection, which would connect to UC400ETH motion controller. The UCCNC software on laptop does the graphic display and communicates the axis moves from g-code to servos via motherboard.... please confirm or edit additional information welcome...
    Mar 2019
    5
    xxx
    35538
    Stepper motors are controlled and powered by stepper drives, which your machine should already have. It probably has a breakout board with a parallel port connection, that will connect to the UC400ETH.
    Stepper drives accept step and direction signals from the controller.
    The UC400ETH should work with any stepper drive.
    UCCNC reads g-code files, and sends step and direction signals to the drives via the UC400ETH.
    You don't need any other software to actually control the machine.
    But you'll need CAD/CAM software to create your g-code.
    I believe that the UC400ETH requires a small 24V power supply.
    Gerry
  1. Joes CNC Model 2006 R-1
    By joecnc2006 in forum Joes CNC Model 2006
    Last Post: 10-04-2018, 02:06 AM
  2. Joes 2006 Vs. Grünblau
    By nuke33 in forum Joes CNC Model 2006
    Last Post: 05-13-2012, 06:08 PM
  3. Joes 2006 in metric
    By firlefranz in forum Joes CNC Model 2006
    Last Post: 05-09-2012, 10:09 PM
  4. FLA vs Joes 2006
    By Bear5k in forum DIY CNC Router Table Machines
    Last Post: 05-06-2010, 04:51 PM
  5. has anyone her add diminsions to joes 2006?
    By mufasa75 in forum Joes CNC Model 2006
    Last Post: 03-22-2008, 05:14 PM
