587,229 active members*
5,551 visitors online*
Results 1 to 2 of 2
    Dec 2018
    1
    mitsubishi z70 alarm
    Hello all, my company bought a m-60e machining center with meldas 500m control. So to get it into the building, we had to remove the z axis motor and encoder, the z70 alarm comes up, in the manual the fix is to run the parameter tape, which we dont have, and do an origin initialization, which i can find no information about. I have experience with only Haas machines so this is definitely out of my comfort zone. If anyone has any ideas on how to get this working, I would appreciate it...thank you
    Sep 2017
    139
    Re: mitsubishi z70 alarm
    Does the machine have ATC or tool loading is manual.. If its manual then the referencing is quite easy. But if there is an ATC you have to do the 2nd referencing and ATC alignments etc.. this would be there in the manual
    Please confirm the parameter , basic spec #11 , and servo parameter sv018 for z axis
