587,491 active members*
4,163 visitors online*
Results 1 to 3 of 3
    Dec 2014
    18
    Gcode for milling a hole from the center
    Hello,
    The CAM software I use (Cut2D) does not allow to mill a hole from the center, it always start from the inner diameter.
    I would like to mill a bigger hole around an existing one so that the head of the screw will 'enter' the material as shown in this picture.
    Can someone provide me the appropriate Gcode to do that?
    The parameter are :
    • Origin : center of the hole
    • Tool diameter : 3.17mm
    • Feed rate: 400 mm/min
    • Cut pass: 0.5mm
    • Plunge rate : any because the tool will plunge in the existing 6mm hole
    Thanks for your help!!
    Feb 2006
    1792
    Re: Gcode for milling a hole from the center
    G02 for CW circular interpolation and G03 for CCW circular interpolation.
    One code would be needed to reach the OD, making an arc, and the next code for complete revolution, machining the OD.
    Dec 2014
    18
    Thank you!
  1. Find center of hole
    By SPRSkip in forum Tormach PathPilot™
    Last Post: 07-05-2015, 04:22 PM
  2. Milling a hole - start the EM in center of hole
    By mkhushf in forum BobCad-Cam
    Last Post: 05-20-2015, 03:27 PM
  3. Finding center of hole
    By georgebarr in forum Mach Mill
    Last Post: 10-08-2009, 12:27 PM
  4. 3/8 shaft with center hole?
    By DennisCNC in forum Community Club House
    Last Post: 09-14-2007, 01:36 AM
  5. pierce for center of hole
    By bearracecars in forum Waterjet General Topics
    Last Post: 09-01-2007, 04:46 AM
