587,443 active members*
3,368 visitors online*
Results 1 to 7 of 7
    Jan 2007
    355
    How do you move an axis manually ?
    Just curious how the DIY router folks manage to jog or move an axis when the need arises.
    I haven't seen ANY mention of this in the posts, but I still have a LOT of reading to do
    Apr 2006
    1016
    Quote Originally Posted by Eurisko View Post
    i herd u can buy a usb game controller and jog the axis with in mach 3?
    Feb 2007
    498
    you can jog it right in mach software,theres a manual jog button and you use the arrow keys for x,y and the page up+down for the z
    or are you talking about when the motors are off,you can mount handles on the motors if they are dual shafted,or on the other end of the screws
    35538
    use MDI mode.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2007
    355
    Most commercial CNC machines have a manual pulse handle ( in addition to the rapid and jog buttons ).
    The rotary handle typically has 3 incremental settings:
    .0001, .001, .010
    Each click of the handle will move the axis the selected amount.
    Great for manual positioning of an axis. Just like a handcrank, but much easier and precise.
    It shouldn't be too tough to come up with a homebrew handle, possibly using a microcontroller and parallel port switch box to switch between handle and auto mode.
    If I ever get my router finished, it will HAVE to have one.
    Feb 2007
    57
    If using mach
    if your using Mach Hit tab and it will pop up
    Mar 2007
    39
    Quote Originally Posted by eloid View Post
    You can there are some downloadable addons on the mach3 site.
    Don
  1. What method did you use to move the x-y-z axis?
    By widgitmaster in forum Polls
    Last Post: 07-04-2013, 04:49 AM
  2. Axis move during feed hold
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-12-2006, 04:12 PM
  3. Manually starting spindle with edge finder
    By diemaker76 in forum Fadal
    Last Post: 04-14-2006, 12:13 AM
  4. Mach 1 x-axis will not move
    By Redline in forum Mach Software (ArtSoft software)
    Last Post: 07-05-2005, 06:01 AM
  5. Speed how fast an axis can move?
    By jlagran he in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2005, 05:05 AM
