587,772 active members*
3,345 visitors online*
Results 1 to 9 of 9
    Jul 2004
    148
    Nema 23 Or 34?
    Ive Been Scanning Through Price Lists And Was Wondering Why I Would Pay More For A Nema 34 Motor Instead Of Just Buying A Nema 23 Motor With The Same Torque At Around 30.00 Dollars Cheaper Per Motor. Is It Because Of The Larger Diameter Shaft On The 34?
    Someone Please Clarify. Thanks
    Jul 2003
    125
    Although the max torque might be equivalent, the torque curves for the two motors probably keeps the 34 ahead (steppers lose torque as they increase rpm, y'know). The 34 is probably overall sturdier as well.
    Apr 2004
    439
    only reason i can think of if you wanted more metal to work with . and the 34 should help a little with heat. be little stronger.
    But no real reason. other then "supply and demand"
    *edit*
    Chagrin is right you should check both motors torque curves amps volts ect
    507
    Is the nema 34 a stepper or a servo, we'll need to move this thread either to the servo or stepper motor forum.
    I'll do it as soon as you guys let me know which one....
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
    Jul 2004
    148
    Reply To Moderator
    Stepper Not Servo, Sorry
    Jul 2004
    148
    Thanks Everyone, I Didn't Think About The Torque Curve.
    35538
    Yeah, from the charts I've seen, typically 34's have flatter curves than 23's
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2004
    75
    But from Dan's sale on Nema 34's, they seem to have cheaper price for torque/dollar compared to his other Nema 23's. Let say 220oz.in Nema23 is the same as 300oz.in Nema34 (around 80 bucks each). Correct me if wrong......
    I think Nema34 is disadvantageous in terms of the torque/weight (of the body) compared to its cousin 23. While 23 with 220oz.in torque is more "efficient" than 220oz.in Nema 34...... What do ya think??
    Andy
    Dec 2020
    3
    Re: Nema 23 Or 34?
    NEMA 34 motors can remove material at a higher rate using higher feed rates and deeper cut depths as compared to NEMA 23.
    https://www.rawlix.com/product/nema-...52358233288547
    https://www.rawlix.com/product/bipol...52260968682280
  1. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  2. Need NEMA 34 to NEMA 23 Adapter
    By jjackson in forum DIY CNC Router Table Machines
    Last Post: 07-01-2010, 02:48 AM
  3. nema 23 vs nema 34. how much power do I need?
    By will gilmore in forum Vertical Mill, Lathe Project Log
    Last Post: 08-21-2009, 03:13 AM
  4. nema 34 1600 oz or nema 42 3200 oz?
    By 15mgtar in forum Stepper Motors / Drives
    Last Post: 07-27-2009, 11:53 PM
  5. Standard Nema 34's vs Nema 34's with encoder/controller.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-16-2006, 05:03 PM
