587,380 active members*
3,863 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Is there a USB wi-fi natively supported by debian/linuxcnc during installation?
Results 1 to 4 of 4
    Sep 2012
    18
    Hi
    I've installed linuxcnc on a pc without a wifi and having troubles adding a wi-fi usb dongle.
    I lean towards reinstalling the whole thing with the usb dongle plugged in (it wasn't), so that debian detects it and installs the drivers.
    I need a recommendation on which usb wifi dongles are natively supported and will be detected at installation.
    Thanks!
    Sep 2017
    10
    Re: Is there a USB wi-fi natively supported by debian/linuxcnc during installation?
    I recently just walked a member of the Linuxcnc forum getting a USB dongle going with a more or less recent version.
    https://forum.linuxcnc.org/pathpilot...iable-usb-wifi
    No need to reinstall........The member in question couldn't get wifi going during installation, but no biggie. The real meat of the answer is the last page or so, the thread is interceded with questions regarding a dying SSD.
    Have a look over yonder and if you need any help I'm always happy to help.
    The cause of the problem, according to "the word on the street" is that some of the firmwares have trouble with the recent Linux network naming convention, as you'll see from the above mentioned thread, it's a simple fix to get the "older naming convention" and to get things going.
    dmesg and lsub are the commands that really help debugging this issue.
    Nov 2017
    6
    If all else fails just pick up and wifi dongle that is compatible with the Debian wheezy os, many years playing with Linux and the drivers are always an issue but they are getting better.
    wifi compatibility
    But not sure how they will affect the RT Kernal.
    Designer-Prototyper-Maker
    Make My Ideas = https://makemyideas.uk/
    Sep 2017
    10
    The issue is some of the realtek firmwares (maybe others) have trouble with the "new" longer naming scheme for network interfaces on newer kernels. The driver will load but it's the firware for the dongle that seems to be the issue. So even if you do grab a compatible dongle it may not work due to the naming scheme.
    Adding these options to the kernel command line, net.ifnames=0 biosdevname=0 goes back to "old" shorter naming scheme for network interfaces, added benefit is that the LAN interfaces go back to eth0, eth1 and so on. After that it's all easy peasy.....a lot of the cheaper ebay dongles use a realtek chip......I think I picked up 4 for the pricely sum of AUD $3.00 a piece delivered.
  1. Linuxcnc installation issues
    By captianpattson in forum LinuxCNC (formerly EMC2)
    Last Post: 07-24-2012, 04:04 PM
  2. V9 Not supported.
    By TheBigJW in forum Mastercam
    Last Post: 01-21-2011, 03:07 AM
  3. G1 with R - not supported?
    By padobranac in forum NCPlot G-Code editor / backplotter
    Last Post: 10-13-2008, 06:35 PM
  4. Debian & Ubuntu EMC
    By pepperwood in forum LinuxCNC (formerly EMC2)
    Last Post: 12-23-2007, 04:10 PM
  5. gcam debian packages
    By technocrat in forum OpenSource Software
    Last Post: 03-13-2007, 12:42 AM
