Hi All,
In my beginning use of RapidTurn, one thing I have observed is a little disturbing. Going thru the manual and doing the first part exercise, I noticed that after using the set G30 button then either running the code or hitting the go to G30 button, the tool only moves on the the Z axis, no X or Y movement. This isn't a problem for the exercise part, but would lead directly to a collision if one were using the tail stock. When on the phone with Tormach for an unrelated issued I asked about it and was told, yes that's how it works.
I didn't think about the tail stock issue until today, and of course, it's the weekend so I can't talk to Tormach. In reading the manual concerning G30, I see that it says the tool will move both in Z and X to values stored in parameters 5181 and 5183, don't know which is Z and which is X, but perhaps the answer for what is happening is that the set G30 just doesn't update the associated parameter.
Continuing to read and play around, I found that if I moved the tool in Z and X and entered G30.1 manually it would go to the correct Z & X if I then entered G30 in the DRO, but if I hit the go to G30 button, it only moved in Z. Additionally, after using G30.1 to set the position I re-ran the exercise code, but when it hit the G30 command it only moved in Z, albeit to the Z I had set using the G30.1 command. The code in the exercise progam contains the line G30 #5422 (park tool). I assume that is a parameter, but it's different from the ones in the manual.
This is a puzzler for me. I'm certainly not a G code expert, but I would have thought G30 was G30, whether as a line of code, or manually from the DRO.
So the point of all this is to ask if anyone else has seen this behavior, and also to ask if any knows how to look at the parameters and see if the change when using the G30 or G30.1 commands.
Terry
