587,747 active members*
2,969 visitors online*
Page 1 of 2 12
Results 1 to 20 of 27
    Feb 2004
    95
    Cutting Aluminum Sheets
    I've built a cnc router with wooden frames and now I'm ready to step up to an aluminum frame machine. What is the best way to cut sheets of aluminum say 3/8" or something. I've cut aluminum sheets on my table saw but never that thick. My harbor freight band saw seems like it would take forever. What is the best way to cut my sheets. Thanks
    35538
    If they are square, the table saw is the way to go. For curved pieces, make a template on your cnc out of wood, rough cut with a jigsaw to within 1/16", then use a pattern bit in a router with the template to finish the edges.
    Gerry
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2004
    95
    What type of blades would your recommend for the table saw and jig saw. I didn't think the jig would cut that thick. I used a carbide blade on it to cut some 1/8" and boy were those chips hot and flying everywhere. I couldn't cut 3/8" in one pass on the table saw could I? Thanks
    779
    It is best to cut in one pass on the table saw. Use a carbide blade and raise the blade as high as it will go, this will make the cutting angle almost in the vertical plane. I have cut 3/4" with no problems. Just move SLOW and protect your eyes and arms.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Feb 2004
    95
    Thanks I'll get me a good blade and try it.
    35538
    60 to 80 tooth triple chip grind (TCG). Wear glasses like Jeff said and cover your arms if possible. (hot chips) But with a sharp blade, it actually cuts pretty easy.
    Gerry
    Gerry
    Feb 2004
    95
    Yeah, that's what I remember from cutting the 1/8" HOT!!! & Messy. That's why I thought the 3/8 might be a bit much but sounds like it will cut ok. Thanks guys.
    Jan 2004
    490
    For the jigsaw blades, get a low TPI. According to the machinist manuals that I have read, tooth count should relate to thickness of the material being cut, ie. a .250 wall tube should have a 16TPI blade, thicker material should be arranged so that at least three teeth contact the material at any given time. Same goes for hacksaw and bandsaw blades too. A little beeswax on the blade will help to keep it from loading up with aly chips too.
    Stop talking about it and do it already!!!!!
    Sep 2003
    1475
    There right. I use a full face shield, long sleeves, the metal is HOT and it gets everywhere.
    I hane cut 1/2" in one pass.
    Hold the material really tightly, stand firmly and don't change your footing when cutting. If you jam the alum/blade the kick back safety feature won't work because the alum is too hard for it to bite into.
    It's a good idea to have another person there to shut off the say if the blade becomes stuck, because you need BOTH hands firmly on that potential projectol.
    With care and precautions you can cut it safely, and the finish isn't too bad either.
    Hager
    Jul 2003
    200
    Hello,
    I cut aluminum daily on a table saw. Mostly 3/8, 1/2 and 5/8 wrought and cast tooling plate...
    Definitely consider getting an aluminum blade, as the zero rake angle makes everything MUCH safer. At a minimum, use the TCG (Triple Chip Grind), though I useta use an atbr.
    FWIW, it REALLY heps to use some lubrication. i've used sprays, both on the blade, and on the cutline, and they work and are less messy than what I'll next describe. Homedepot sells a spray lube that I've had reasonable success with.
    But the best is to use the beeswax lube stick available at machine shop supply houses. You can also use a BEESWAX (be sure it's not some modern synthetic, as they're becoming more common!) toilet bowl seat ring.
    I rub this against the spinning blade--both sides-- before cutting. And I "draw a line" of beeswax down my cut path, so the blade pulls it into the cut. It makes a HUGE difference in cut quality, and ease of feeding.
    Safety is a BIG issue when you do this, so heed the advice to protect your eyes, hands and arms. On a day that I 've cut a lot of parts this way, my arms look like I have measles from the tiny cuts made by flying shrapnel (Because using long sleeves, which would prevent the cuts, leads to another safety problem, that of catching a sleeve. Since I'd rather have many tiny scratches instead of one huge cut, I put up with the flying bits.)
    Should say here that I'm a lifetime table saw user, and have not had the plastic guard on in years. I'm sure it would help immensely. For me it presents other problems, but I'd be remiss in suggesting you follow my lead and not use it.
    anyway, be sure you have "tuned up" your saw before cutting aluminum. You want the bearings and belt(s) tight, and the miter gauge and rip fence settings exact. No 1/16 bigger at the outfeed end!
    And I'll make one observation in disagreement with what others have said. Although I often do cut full depth in one pass, I have had great results in taking several cuts. If you flip the part it will take only a few passes to go through, even with a lower grade table saw. Mine are heavy duty industrial types. With the multiple cuts, you can get the beeswax into the groove of the prior cut...
    Also, consider using a two-step sizing operation. Get the piece cut though using multiple passes, but a BIT oversize. Then "true it up" to size with a full depth cut, taking less than 1/16 from an edge. You'll be safer, and have great results!
    Hope this helps,
    Ballendo
    35538
    A sliding crodsscut sled will make things safer and easier as well.
    Gerry
    Gerry
    Feb 2004
    95
    Thanks, I went to Lowe's to see if they had a blade that I could use but of course I couldn't find any that stated anything about TCG (Triple Chip Grind), what is that is that? I just bought the nicest titanium carbide blade I could get 60 tooth. Were do I need to go to get a good blade for aluminum on the net or where ever like ballendo suggests? What is atbr?
    Jun 2003
    3312
    I just use a Freud 60t thin kerf carbide blade, works great. I think you will find most blades if not specified alternate bevel. In fact once I got the nerve to cut 6061, it turned out to be much less difficult to cut than Hard Maple.
    Phil
    Apr 2003
    1873
    the "A" is alternating
    Here is alink for 10" metal cutting blades.
    About the price of a good wood cutting blade.
    A little pricy but I would expect it to be a good investment.
    http://hawksawblades.com/Merchant2/m...ory_Code=MD100
    Feb 2004
    95
    Hey and there even in my town. Thanks
    Apr 2003
    7
    cutting sheets
    see if your vendor has a plate saw and see if he will cut it close to your dim. I have cut up to 1/2 with a circular saw but it was pretty hairy
    35538
    http://www.cheyennesales.com/catalog/cmt225.htm
    I recently purchased something from them, and got pretty good service, btw.
    Gerry
    Gerry
    Jul 2003
    200
    Here's a pic (from the Freud site)-- I hope
    Ballendo
    Jul 2003
    200
    Hello,
    It worked! But in my excitement I forgot the rest of the message
    "H" in the pic is the rake angle. Will be typically 6-7 degrees for wood cutting, but should be 0 degrees for aluminum. 0 degrees means the tooth face is ON the diameter, and parallel to it.
    Aluminum blades can be found in most cities. Contact the local "window" mfrs and installers and ask them who "does" their blades...
    ATBR? Alternate Tooth Bevel, w/Raker
    In this blade you have point left, point right, point left, point right, flat top (the raker). So the blade is always a multiple of 5 teeth.
    50 and 100 are common.
    Hope this helps,
    Ballendo
    P.S. A TCG is the best for the plastics too. Again with the atbr as a second choice.
    If you decide to use a simple ATB-Alternate Tooth/Top Bevel, be SURE you're protected, because you will very likely be losing the tips of your saw teeth. (corners, hopefully not the full tooth! But I've seen that too, if the operator is not careful to have the work supported throughout the cut!)
    35538
    The CMT non-ferrous blade I posted the link to has a -7° rake. The negative angle is a little safer still, then the 0°.
    Gerry
Page 1 of 2 12
  1. Cutting fluid for aluminum?
    By Ben in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2011, 04:03 PM
  2. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
  3. Cutting fortal aluminum
    By JRoque in forum Uncategorised MetalWorking Machines
    Last Post: 07-16-2004, 01:51 PM
  4. what aluminum has the smoothest cutting properties
    By replicapro in forum MetalWork Discussion
    Last Post: 07-10-2004, 05:11 PM
  5. Cutting aluminum with an end-mill bit
    By camfambmw5 in forum CNC Machining Centers
    Last Post: 02-09-2004, 12:59 AM
